Help with Maintenance Code
Old Dec 7, 2005 | 01:45 PM
jmoonan's Avatar
jmoonan
Question Help with Maintenance Code
The check engine light on my 98 ES300 is on. I had the code read out and it is P0135 "O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1). Can anyone explain what this code means and what I have to do to correct it. I replaced the bank 1 O2 sensor and had the code reset but it just came back.
Thanks, John M
Old Dec 7, 2005 | 04:30 PM
VVT-i's Avatar
VVT-i
Bank 1 sensor 1 is the sensor closed to the firewall. Which sensor did you replaced? You can use the " Search " function and type in O2 sensor and you will find a lot of good info about this topic.
Old Dec 7, 2005 | 07:36 PM
Dx3's Avatar
Dx3
P0135 - Trouble areas are -
Open or short in heater circuit or heated oxygen sensor
Heated Oxygen sensor heater
ECM
is what the manual says.
Jonny
PandaGS300
Apr 6, 2015 01:40 PM
grillzrho
Apr 24, 2013 09:16 PM
00&02rx300
RX - 1st Gen (1999-2003)
Jan 27, 2010 06:17 AM
nicos1
Nov 5, 2007 05:47 PM
beavis1
Maintenance
Oct 17, 2003 03:38 PM
