Ignition Problems
Old Apr 29, 2005 | 12:32 PM
vtrd00d's Avatar
vtrd00d
Default Ignition Problems
Hi new to the forums... Need some help.
I have a 97 ES300,
Im having problems with the starter/ ignition switch.
When i start my car the starter stay on the fly wheel, and makes a terrible noise that of a dieing rodent.
When i turn the ignition off, take the key out, the starter is still turning my motor over like its trying to start it. WTF? I have to disconnect my battery for it to stop.
I was wondering if anybody else has had this happen or know what i should do?
Thanks!
Old Apr 29, 2005 | 12:53 PM
amf1932's Avatar
amf1932
It sounds like a problem with the starter solenoid. In any case, the starter motor has to be removed to check out this problem.
Old Apr 29, 2005 | 04:09 PM
VVT-i's Avatar
VVT-i
Welcome to CL. Sorry to hear about your problem, but you need a new starter. You need to get it fix asap, because if the starter gear stays engaged for so long it will ruein the flywheel.
Old May 4, 2005 | 10:27 AM
vtrd00d's Avatar
vtrd00d
sorry to bump this tread,
But thanks for the help and the welcome, it turned out my solenoid was shot and my clutch. got a guy to rebuild the entire starter for $70
Thanks again!
AudioMan
RX - 1st Gen (1999-2003)
34
Oct 22, 2020 08:03 AM
gario
Jul 22, 2011 10:11 PM
meanboy
Apr 22, 2008 02:22 PM
b1gredek
Oct 7, 2004 08:45 AM
TrboHead
May 2, 2003 10:40 PM
