Maintenance Required light GX470
Old Nov 2, 2004 | 07:35 AM
audphile1's Avatar
audphile1
Default Maintenance Required light GX470
Anybody knows how to make Maintenance Reuired light go away on the instrument panel of '03 GX470 without going to the dealer? Thanks.
Old Nov 2, 2004 | 07:39 AM
jnguyen's Avatar
jnguyen
i think your suppose to reset it but not sure how to
Old Nov 2, 2004 | 09:03 AM
CdeFabio's Avatar
CdeFabio
I do not have my book with me now, but the directions are in the owners manual. Sorry I could not be of more help but at least it gives you a place to start. I hope that helps!
Old Nov 2, 2004 | 10:09 AM
audphile1's Avatar
audphile1
It would be great If it's in the manual, I will be able to look it up later on today. I was not sure that it is there. Don't have manual on me right now. Thanks.
Old Nov 2, 2004 | 12:53 PM
CdeFabio's Avatar
CdeFabio
Post
I checked the manual and here it is:
Engine Oil Replacement Reminder Light
(for vehicles sold in U.S.A.)
This light reminds you when to replace the engine oil.
This light will come on when the ignition key is turned to “ON”
and will go off after about a few seconds.
When you drive for about 7200 km (4500 miles) after the
engine oil replacement, this light illuminates for about 3
seconds and then flashes for about 12 seconds with the
ignition key turned to “ON” position. If you continue driving
without the engine oil replacement, and if the driving range
exceeds 8000 km (5000 miles), the light will come on after the
ignition key is turned to “ON” position. The light will remain on
thereafter.
If the light is flashing, we recommend that you replace the
engine oil at an early opportunity depending on the driving and
road condition. If the light comes on, replace it as soon as
possible.
You need to reset the light after the engine oil replacement.
Reset the light by following the procedure below:
1. Turn the ignition key to the “OFF” position with the odometer
reading shown. (For details, see “Odometer and trip meter” on
page 50.)
2. Turn the ignition key to the “ON” position while holding down
the trip meter reset ****.
Hold down the **** until the light goes off. Before the light
goes off, it illuminates for 3 seconds, flashes for 2 seconds and
illuminates for 1 second.
If the system fails to reset, the light will remain flashing. In this
case, return to step 1 and try again.
Hope this helps!
Old Nov 2, 2004 | 04:16 PM
audphile1's Avatar
audphile1
thanks a lot for going the extra mile. I will give it a try.
Old Nov 3, 2004 | 05:24 AM
CdeFabio's Avatar
CdeFabio
Thumbs up
No problem. Good luck!
Old Sep 28, 2014 | 04:52 PM
sharenee09's Avatar
sharenee09
Thank you great help to the point couldn't be better
astoria12
16
May 23, 2015 04:19 PM
memphisto
GX - 1st Gen (2003-2009)
Feb 5, 2013 05:18 AM
ivey23
Jun 11, 2010 01:44 PM
judyh831
Jul 21, 2007 05:49 PM
p34m23
Oct 30, 2006 05:57 AM
