Wheel Bearings
Old Apr 22, 2001 | 08:29 AM
iluvlex
Guest
Posts: n/a
Has anyone ever had to change their wheel bearings... my left rear bearings have gone bad and I would like to know how much.
TIA
Old Apr 22, 2001 | 10:32 PM
DevilDog's Avatar
DevilDog
Are you sure it's bad? Was is diagnosed by a technician? I have seen a couple of high mile coupes with the same problem. It turned out to be the transmission mount. Sounds crazy but true. If the mount collapses it will send a bad vibration through the car sounding like a bad bearing. Did your tech listen to the bearing with a stethiscope? That what I use when I need to check a bearing.
Old Apr 23, 2001 | 07:55 AM
iluvlex
Guest
Posts: n/a
There is no vibration at all. The rotor gets really hot and if i drive it too long... I get a burning smell from it.
At first I thought it was a bad caliper causing friction to the disc but there was no brake dust and the car wasn't pulling to one side.
My coupe has 173k so I'll keep that transmission mount in memory.
Best Regards
Old Apr 24, 2001 | 11:35 AM
bmm89's Avatar
bmm89
Not on a lex, but on my honda. Look for play, irregular rotation when your wheels are off. It's not a do it yourself on imports with sealed bearings though, better take it to a shop. Unless you have access to a hub compessor like i do.
12jimmyjam
23
Jan 3, 2020 07:24 PM
dparker
Jun 17, 2018 03:37 AM
Greg5OH
16
Jun 14, 2016 12:23 PM
azimali
Jun 9, 2014 04:06 PM
r3dl4b3l
RX - 1st Gen (1999-2003)
Oct 5, 2009 09:48 AM
