Fuel eater
Old Sep 30, 2004 | 11:49 PM
HarrierAWD's Avatar
HarrierAWD
Originally posted by nthach
go to a GM dealer and get a can of GM Top Engine Cleaner. Suck the can through a vacuum port slowly, and then all at once until the engine dies. Then wait a 1/2 hour. Start up the engine, don't be alarmed if it smokes like a ****.
The GM top engine cleaner is for engines with serious carbon deposit on piston heads. I doubt it's his problem.
Also, that's not how you use the GM Top Engine Cleaner. You are supposed to remove all spark plugs. Pour the Top Engine Cleaner into each cylinder. Let it sit overnight. Then put a rag on top of the engine and crank it until all gunks are out of the plug holes. Then put the plugs back in. Yea, like you said, it will smoke like a grandmofo for a while.
I think it's easier to just buy a Toyota. (Ex-GM owner here.)
Old Oct 2, 2004 | 05:17 PM
THE_CEO's Avatar
THE_CEO
Default Re: Fuel eater
Originally posted by Ghetto-Pimp
my car eats lots of Gas
my car has like 130 000 miles on it right now and its eating lots of gassss for some reason
i used to get like 270 miles on a full tank
and now i get 170 on a full tank
i dont understand what happened here,
my car been doing this for about a month now
does anyone else have this problem
i looked in the fuse box, my fuel relay is missing, i dont know if it was never there before or what,
its the relay next to the AC Relay, could this be the problem
please help thanks
What kind of Lexus is it?
CEO
Old Oct 2, 2004 | 07:27 PM
VVT-i's Avatar
VVT-i
From your posts, look like you got a 1995 ES300 with air intake, dropped and 18'' rims.
You may need to check or get a reading of your O2 sensors to see how fast your O2( both banks) respone. Also, check your EGR system as well.
How's your emission reading?
Old Oct 3, 2004 | 12:16 PM
ArmyofOne's Avatar
ArmyofOne
Dysfunctional Veteran
Veteran: Army
heh i totally forgot about this thread.
nope, a bottle of Slick 50 fuel system cleaner and a few tankfuls fo premium gas did the trick.
Old Oct 4, 2004 | 03:18 AM
Ghetto-Pimp's Avatar
Ghetto-Pimp
sup
yeh i have a 1995 lexus es 300
i was thinking about the O2 sensors
where can i get it checked, how much will it cost,
Stage3
Aug 10, 2023 05:40 PM
arf1410
NX - 1st Gen (2015-2021)
May 8, 2019 05:14 PM
sho89mtx
Nov 11, 2011 01:42 PM
