bleeding brakes on LX
Old Jul 21, 2004 | 11:36 AM
roberttran's Avatar
roberttran
Default bleeding brakes on LX
Hey,
I just read the section on breeding the brake system in the repair manual and I would like to confirm this is what I'm suppose to do:
1. With ignition switch off, press brake pedal about 40 times
2. Turn ignition switch on, press brake pedal about 20 times
3. Bleed front calipers ( with ignition switch on?)
4. Bleed rear calipers with pedal depressed
It doesn't say so, but it seems I do this with the ignition on? I thought it had to be off. Also it says to do the front calipers first. I thought you should always do the rear ones first since it was furthest from the brake system.
Thanks,
Robert
Old Jul 21, 2004 | 12:04 PM
PHML's Avatar
PHML
Master Thread Closer!!
I found this....hope this helps.
Pete
Bleeding Brakes FAQ and Step-by-Step Instructions
How often should you bleed your brakes?
Manufacturers usually specify that brakes should be bled every two years, starting from the date the vehicle was built. For race cars, it may be necessary to bleed the brakes before each event and, if the pedal becomes soft during an event, it may even be necessary to bleed between sessions. If you find yourself bleeding the car between sessions, it's time to consider using a brake fluid with a higher boiling point, such as Motul 600.
Why bleed brakes?
Fresh brake fluid has a significantly higher boiling point than old fluid, allowing harder braking without fade. This is because brake fluid is hygroscopic and readily absorbs moisture. The more moisture in the fluid, the lower the boiling point.
That same moisture promotes corrosion. Frequent bleeding with fresh fluid allows brake components to last longer. A well maintained brake system can help you avoid having to replace or rebuild calipers or replace an expensive ABS control unit.
The bleeding process may remove air bubbles from the hydraulic system, resulting in firmer brake pedal feel and more linear, responsive braking performance. Too much air in the system can be dangerous and result in the pedal sinking all the way to the floor. Air is compressible, brake fluid is not.
How much brake fluid is required?
It is usually possible to bleed all four wheels with somewhere between 1/2 and one liter of brake fluid. If you've just installed new brake lines or a big brake kit, it may require more fluid, especially if you are a novice at bleeding.
Must brakes be bled in a specific order?
Bleeding is done one wheel at a time. The "old timers" will tell you to start with the wheel furthest away from the master cylinder and then work your way closer. Typically, this would mean RR, LR, RF, then LF. However, it doesn't really matter if you start with the front or rear wheels, since they are on separate brake circuits on modern cars with ABS and/or dynamic stability control systems. However, you should start with the passenger side wheel and then do the driver's side.
How are brakes bled?
There are many techniques for bleeding brakes and lots of gadgets to make the job easier. Click here for some examples and my comments on them. For simply replacing old fluid with new, many of these techniques work well. But for removing air bubbles from the system, only one approach works. That is the old fashioned method which requires an assistant to push on the brake pedal while the mechanic opens and closes the bleed valve on the calipers. This is the only way to generate a sufficient jolt to the brake fluid to knock loose those pesky bubbles and allow them to be flushed away. By following these instructions, you will be more likely to end up with a firm brake pedal, often with better feel than the day your car rolled off the assembly line.
1. Block a front wheel with a piece of wood to prevent the car from rolling. Raise the back of the car with a floor jack and then lower it onto a pair of jackstands.
2. Remove the rear wheels.
3. Open the hood and remove as much old brake fluid from the reservoir as possible, using a suction tool or a turkey baster. Be careful not to spill any fluid, as it will dissolve the paint on your car.
4. Fill the brake reservoir to the top with fresh fluid.
5. Place a box end wrench over the bleed screw on the right rear caliper. Push a clear plastic tube over the nipple on the bleed screw and place the opposite end into a bottle. Alternatively, you can buy a catch bottle with a cover that prevents fluid from spilling if it tips over, a 1-way check valve in the cap, and a rubber fitting on the caliper end of the plastic line that snaps in place over a wide range of bleed screw nipple sizes.
6. Tell your assistant to pump the brake pedal a few times until it becomes firm. This is especially important if you have just replaced pads. If you've installed new stainless braided brake lines or installed a big brake kit, there may be enough air in the system that the brake pedal will not get firm. That's OK. Just move on to the next step.
7. Tap the caliper a few times with a rubber mallet. This helps to release air bubbles that may be clinging to inside surfaces of the caliper.
8. Have your assistant PUSH hard on the brake pedal and HOLD. Then quickly, crack open the bleed screw about 1/4 turn. Fluid (and probably a few air bubbles) will flow through the plastic tube and into the catch bottle. A light placed behind the tube will make it easier to see what is coming out of the caliper.
9. Close the bleed screw just before the brake pedal reaches the floor. Don't worry if the timing is off at first. You will quickly figure it out with feedback from your assistant.
10. Tell your assistant to RELEASE.
11. After a brief moment, repeat steps 8 - 10. Do this about 6 times and then go to the front of the car to make sure the fluid level has not dropped too far. You MUST not allow the fluid level to fall to the point where you are sucking air through the master cylinder.
12. Top off the brake fluid level and continue for a total of about 10 pumps or until you no longer see any air bubbles coming out of the caliper.
13. Repeat the process for the other rear caliper.
14. Make sure both calipers are wiped clean of brake fluid and that none has spilled on the rotors or pads. Use brake cleaning spray if necessary. Reinstall the rear wheels and torque to factory specification, then lower car to the ground.
15. Now apply the parking brake, put the car in gear (or PARK) and raise the front of the car with your floor jack. Lower it onto a pair of jackstands.
16. Remove the front wheels.
17. Follow the exact same technique as with the rear wheels, starting with the passenger side caliper. The fluid will flow more rapidly out of the front calipers, so you will need to check the level in the brake fluid reservoir more frequently to avoid letting it drop too low.
18. Reinstall and torque the front wheels, then lower the car to the ground.
19. Top off the brake fluid reservoir and replace the cap.
Old Jul 24, 2004 | 10:02 PM
JCtx's Avatar
JCtx
Or just use a vacuum bleeder (about $60, and they come with a big, self-pouring bottle so no need to add fluid to the reservoir) and do the job yourself... faster and safer (no coordination required with the helper).
By the way, there's no need to remove the wheels at all; I put my cars on ramps, and I just slip under my SUVs (even faster).
And yes, if your car has VSC (4 independent circuits), no particular order is required.
Hope this helps.
goose300
Aug 27, 2022 06:17 PM
potatomon
Apr 15, 2019 04:41 PM
SHEL07
Sep 4, 2009 04:36 PM
lex400sc
Jun 7, 2004 11:13 PM
clivej
Aug 20, 2001 12:05 PM
