front brakes
Old Aug 16, 2001 | 02:47 PM
clivej's Avatar
clivej
Hi Guys ,
need some help here, just changed my front brakes, no problem,removed housing,opened brake fluid container.pushed back calipers,installed new pads(plus old shims) and put it back together.NOW my pedal feels soft when i apply the brakes,drove it around awile,still soft,did i @#$% it up?NEED help.The car still stops,Just the feel is different.
Old Aug 16, 2001 | 02:50 PM
BLiu's Avatar
BLiu
Did you bleed the brakes? You might have some air trapped in the brake lines...
Brent
LexusRules's Avatar
LexusRules
you need to bleed the brakes, to do this you have to open a little screw on the caliper and get a friend to push the brake pedal ONE TWO THREE and HOLD... 2 seconds... realease, do this three times, then it will be better hope this helps
Old Aug 16, 2001 | 03:00 PM
clivej's Avatar
clivej
HI Guys
Did not bleed the brakes,read somewhere that the brakes on these cars should not be bled,mess's with the traction control,and VSC. however i am willing to try the bleeding thing,need procedure though,please post such.thanks.
Old Aug 16, 2001 | 03:11 PM
LexusRules's Avatar
LexusRules
its in my other post
just open the little valve, press the pedal three times and on th third time hold it until nothing is coming from the valve anymore, do this about 3 or 4 times on each brake, then close the valve
Old Aug 16, 2001 | 04:02 PM
clivej's Avatar
clivej
Question Do I need to have the engine running(hydraulics) and do I need to open the brake fluid container?
Old Aug 16, 2001 | 04:05 PM
LexusRules's Avatar
LexusRules
no and no
but in the end add a bit more brake fluid as you will most likely have drained some
Old Aug 16, 2001 | 04:37 PM
clivej's Avatar
clivej
thanks Guys,
will do tomorrow as my help is gone to the movies.
Old Aug 16, 2001 | 06:51 PM
nanotech's Avatar
nanotech
Is it really that complicated to replace your rotors, etc?
I am thinking about upgrading rotors, brake pads, brake lines, and maybe calipers too....should a toyota dealership be able to do this easily? (Lexus is an hour away, plus I know the toyota people here)
Old Aug 17, 2001 | 09:37 AM
clivej's Avatar
clivej
hi nanotech
I think the toyota guys should be able to handle this.
Old Aug 17, 2001 | 10:09 AM
xsuperjoex's Avatar
xsuperjoex
Yes and Yes!!!
How is a Hydraulic pump going to work without power to it? Your car has to be on with motor running and the cap of the brake resiviour off.
Old Aug 17, 2001 | 10:10 AM
xsuperjoex's Avatar
xsuperjoex
I only know this because i just did my brakes with new fluid (Motul), lines, rotors and pads.
Old Aug 17, 2001 | 10:52 AM
LexusRules's Avatar
LexusRules
i'm an idiot, but i never thought the car should be running, but now that i think about it idid no that that the resevoir had to be open
Old Aug 18, 2001 | 12:22 PM
clivej's Avatar
clivej
Hi guys,
Bled the brakes this morning ,NO change, the brakes are still spongy,will have to take it in i guess,AYE WELL,
sometimes you just can't win,
Thanks guys
Old Aug 18, 2001 | 12:57 PM
LexusRules's Avatar
LexusRules
sorry we couldn't be of better help
good luck in fixing it!
