120k service
Old May 13, 2004 | 09:37 AM
TGRich's Avatar
TGRich
Default 120k service
Ok, did a search for this and I don't think everything was covered in one post, so I'm hoping to get a COMPLETE list for the 120k service of sc300s.
My car is a 1993 sc300 5 speed running on borrowed time since I'm above 120k now and I need to do the timing belt. Here' s my list so far and please add to it if you can think of anything else
Serpentine belt
Timing belt
Idle pulley tensioner replacement
Timing belt tensioner replacement
New cam and crank seals
valve cover gaskets
water pump
fuel filter
valve adjustment with shims
tranny fluid
brake fluid
power steering fluid
distributor cap and rotor
New upper & lower radiator hoses with new clamps and a new thermostat w/ new gasket. (If needed)
coolant flush and change
Can anyone think of anything else?
Thanks for your help guys
Tim
ps- Carson has the serpentine belt for $55, which sounded a little high to me. Is this right, or does someone have the OEM Toyota part cheaper?
Old May 13, 2004 | 09:41 AM
indypwr's Avatar
indypwr
Post
what's 'serpentine' belt? is that the same as fan belt?
Old May 13, 2004 | 09:51 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Maintenance?
moved :0)
Old May 13, 2004 | 11:30 AM
mikeloc24's Avatar
mikeloc24
Default $$$$$$ for 120k service
Originally posted by TGRich
There's two seals I forget the name of (someone help here)
Tim
Tim, the 2 seals you may be referring to are the valve cover gaskets. I changed mine about 2 months ago as they were leaking, they ran me $21 each from the Lexus dealer here in Beverly Hills. The part number is #11214-46011 & #11213-46020. There's also an o-ring seal behind your distributor, costs $2 (don't have the part number, but they'll know which one...it's common)...might as well change that one too because it'll be leaky soon. Lemme think what else....oh yeah, the serpentine belt...I get my belts from a place here in LA called "Certified Undercar Parts", they're really good and carry Gatorback belts, that's what I have in my SC300. I think my serpentine belt was like $30, best price I could find and a GREAT belt. I'll post if I think of anything else...by the way, regarding the valve adjustments, how do you know that needs to be done?
Indypwr, no the "serpentine belt" is the main drive belt (you can see it when facing the engine with the hood open..it's between the fan and the engine). The fan belt is closer to the radiator and doesn't "snake" around as many pulleys.
Old May 13, 2004 | 12:34 PM
singh99999's Avatar
singh99999
How do your spark plugs look?
Old May 13, 2004 | 01:14 PM
TGRich's Avatar
TGRich
Brian- we all now nobody reads the maintenance forums
Yeah, I forgot the plugs and wires, but that was done back at about 88k along with the fuel filter. I also did the cap and rotor, brake fluid, and tranny fluid recently too.
As for the valave adjustment, I don't know if it needs it- that's something that has to be measured once your in there.
Tim
Thanks for the help so far, is there anything else I'm missing
Old May 13, 2004 | 03:15 PM
mikeloc24's Avatar
mikeloc24
Default yes there is!
A surplus of cash, like most of us, now get the heck out here already and stop stalling!
Old May 14, 2004 | 12:22 PM
SharpLS-96's Avatar
SharpLS-96
Idle pulley replacement.
Timing belt tensioner replacement.
New cam and crank seals.
Old May 14, 2004 | 04:10 PM
TGRich's Avatar
TGRich
Cool, cool. I just edited the original post to include everything. If anyone can think of anything else, please chime in.
Old May 14, 2004 | 06:12 PM
SharpLS-96's Avatar
SharpLS-96
You can also delete the two seals you were asking about since I mentioned them.
Old May 14, 2004 | 11:37 PM
TGRich's Avatar
TGRich
So the cam and crank seals are the same as the valve cover seals?
edit*never mind, its late and im buzzed- I got what you mean now
Old May 17, 2004 | 09:27 AM
TGRich's Avatar
TGRich
Default Re: $$$$$$ for 120k service
Would you be able to get me a web address or phone number for Certified Undercar Parts?
Thanks,
Tim
Old May 17, 2004 | 02:33 PM
mikeloc24's Avatar
mikeloc24
Default Certified Undercar parts
Tim, here you go, let me know if you need anything (I'm not a mechanic or affiliated with this shop in any way other than as a walk-in customer, I believe they serve primarily mechanic shops as they're not a typical parts retailer store, more like a warehouse, but they carry EVERYTHING and usually carry 3 levels of parts- cheapie, OEM, and high performance, good luck): Certified Undercar Parts, 1156 N. Las Palmas, Los Angeles, CA 90038. Phone #323.962.7200
Old May 17, 2004 | 02:38 PM
TGRich's Avatar
TGRich
Thanks Mike. I just called them and the dude on the phone sounded frantic. He was talking so fast even this NY'er couldn't understand him. I guess they were busy. He said the only one they had was a Goodyear belt and it cost $27. Does anyone know anything about the quality of the Goodyear belt?
Should I buy this one or spring for the $55 OEM one?
Thanks,
Tim
Old May 28, 2004 | 12:27 AM
TGRich's Avatar
TGRich
Ok, I'm driving up to Carson to pick up my parts tomorrow and I'm going to try to get the service done over the weekend. Does anyone have any tips on doing this such as what order to do the things in (water pump first, tbelt first, etc)? Also, any other helpful tips would be appreciated.
Oh, and I remember seeing that there's no need to mess with the timing when replacing the tbelt, but can anyone confirm this? do you just line up some marks or something so the belt is in the same position as the old one?
