What Order to Bleed?
Old Feb 28, 2004 | 06:42 PM
gebo's Avatar
gebo
Default What Order to Bleed?
'98 LS400. I am changing brake fluid and have a "Power Bleeder." As I drain and replace my brake fluid, I believe I start bleeding at the wheel farthest away from the master cylinder, i.e., right rear. Then I go to left rear and then I go to right front and end up at the left front. Is this correct?
Old Feb 28, 2004 | 09:35 PM
99lsguy's Avatar
99lsguy
You are correct!
Old Mar 5, 2004 | 04:34 PM
Carpe Diem's Avatar
Carpe Diem
I'e follow that pattern for years but recent have decided it doesn't matter at all for a bleed job. In that you're just pulling down a little fluid. The only logic I can see in it at all is for a flush. Then flushing the longer lines till clear first might save you a little fluid but, for what brake fluid costs, so what.
I wish someone would explain to me why, for modern cars, we think that order is important. I bet it goes back ancient brake system design.
George
RageRacerM
Suspension and Brakes
Nov 20, 2018 08:05 AM
KC98LS
Jun 28, 2016 02:21 AM
sw2oboi
May 23, 2010 11:01 AM
ToyotaLexus
Feb 16, 2009 07:46 PM
500amg
Maintenance
15
Feb 7, 2003 11:38 AM
