00 es300 turn light problem
Old Feb 16, 2004 | 02:20 AM
UncivilizedAMD's Avatar
UncivilizedAMD
Default 00 es300 turn light problem
Both my front left and rear left signal lights have a problem. They both went much dimmer than normal and the left turn signal blinks real fast. Problems with both lights occured at the same time. Anybody know what's the problem and how to fix.
thxxx
Old Feb 17, 2004 | 06:00 AM
Traturn's Avatar
Traturn
Try replacing the bulb and it's socket.
socket - 90075-60051 and its a dual filament 1157N bulb (amber)
probly do both sides. (front turn signal)
Old Feb 17, 2004 | 03:03 PM
VVT-i's Avatar
VVT-i
Most of the time it's just the front turn signal bulb. This bulb( amber) is double filaments, so it use as corner light and turn signal at the same time. You will see the front turn signal light is blinking, but one of the filament is gone.
Just remove the plastic clips the hold the black plastic cover around the head light. Then you will see one philip screw, remove the screw and gently pry out the turn signal len. Replace the bulb, check make sure it's work and you're done.
Old Feb 19, 2004 | 08:25 PM
22lbGS-R's Avatar
22lbGS-R
Alot of the time what i have seen is just a bad connection on the front light and if you hit it a couple times with the light blinking it should fix the blinking fast problem.
knchen
May 15, 2010 01:32 AM
tomsmr2
Apr 14, 2007 12:59 PM
lasracin
Sep 14, 2005 06:29 AM
BlackSC300
Aug 6, 2005 11:18 AM
ebandaz
Lighting
Feb 19, 2004 02:08 PM
