car shakes at 60-65mph
Old Dec 16, 2003 | 02:08 AM
shyvpboi's Avatar
shyvpboi
Default car shakes at 60-65mph
Ok my car runs smoothly at near every speed, but around 60 to 65mph it starts to rumble. This problem has been going on for a long time...i need your help please! I've already balanced the tires and got an alignment done. What else could be the problem?
Old Dec 16, 2003 | 05:56 AM
DIrEctQL's Avatar
DIrEctQL
Chicago Lexus Club Moderator
Default Re: car shakes at 60-65mph
Re-balance your tires. I had the same problem not so long ago.
Chris
Old Dec 16, 2003 | 07:54 AM
jgbnm's Avatar
jgbnm
I had a similar problem a couple of years ago from about 75-85 mph. Alignment and tire balancing didn't help, but a second tire balance did the trick. Not sure if it was due to a better machine or a better operator but I won't go back to the first shop.
Jon
Old Dec 16, 2003 | 10:17 AM
Lexmexico's Avatar
Lexmexico
Have you had your tires rotated?
Another thing that plagues my RX is having two many stones in the tires. Every 6 months, I take the time to get them out. It made a BIG, BIG difference.
The balancing is probably the cuplrit. I used to have Midas do it here in Mexico, but then when Toyota came here, I started doing it with them. It made all the difference.
Old Dec 16, 2003 | 10:58 AM
Faceless1's Avatar
Faceless1
You can have the tires balanced again, but make sure that the front and rear rims are checked for runout. The rims can be out of round and that will cause a shake, even if your tires are balanced perfectly. A bent rim can be difficult to see on the vehicle, but on a tire machine spinning, it can be detected.
Good Luck
Old Dec 16, 2003 | 11:46 AM
shyvpboi's Avatar
shyvpboi
Thumbs up
thanks a lot guys
Old Dec 16, 2003 | 12:59 PM
mooretorque's Avatar
mooretorque
Go here:
http://128.242.141.111/pub/search/FindGSP9700.cfm
and find the nearest 9700 machine to you. Whoever/wherever that is, go there. This machine ought to be able to answer all questions regarding balancing and wheel runout.
2slixx
Mar 6, 2012 07:27 PM
jasonlee
Suspension and Brakes
Apr 17, 2009 04:23 PM
lexsc3
Wheels, Tires & Brakes Forum
Nov 18, 2004 04:04 PM
PearlLex
Apr 8, 2004 04:21 AM
aldo23
Jan 13, 2003 02:35 PM
