Is there only one size oil filter canister remover?
Old Feb 22, 2025 | 08:16 PM
dougdangger's Avatar
dougdangger
Default Is there only one size oil filter canister remover?
Hey everyone.
I have a 2010 Toyota Rav4 4 cylinder that uses the dreaded plastic canister oil filter.
I also have a 2025 Lexus ES 350 that should also use the plastic canister oil filter. I haven't seen it, tomorrow's the first oil change.
My question to anyone here is do they use the same size canister wrench? If so then I have the tool for the Rav4 to all is good. If not then I will have to hit up Amazon and order one.
Old Feb 23, 2025 | 09:27 AM
chas410's Avatar
chas410
Thinking it should be the same. Looks to take the same filter. Toyota filter 04152-YZZA1 or a WIX 57047. I want to suggest using a torque wrench. Oil Drain Plug 25 ft lbs. Filter Housing 18 ft lbs. & Oil Filter Drain Plug 9 ft lbs.
nzahra11
NX - 2nd Gen (2022-current)
Feb 14, 2024 11:39 AM
dotnet93
RC - 1st Gen (2015-present)
Aug 28, 2023 11:02 PM
leehom
NX - 1st Gen (2015-2021)
Oct 1, 2022 09:17 AM
IS350atWOT
Jun 30, 2014 02:04 PM
Lexus@17
Feb 12, 2010 05:17 PM
