Coolant level question
Old Oct 29, 2023 | 07:48 PM
e-man's Avatar
e-man
Thanks for all of your help. I just added a bit of coolant to the reservoir. It is now about a half an inch above the low line when cool. I also misunderstood the point of the reservoir. For some reason, I thought that the coolant would drain out the bottom of the reservoir and into the radiator when needed. I didn’t realize that it actually gets sucked out through the top.
and for what it’s worth, I just took a five hour round-trip road trip on Friday. I watched the temperature needle very carefully, and it never budged from right in the middle.
Old Oct 29, 2023 | 08:14 PM
A good tell to see if coolant level is okay is if you have proper heat. If you ever hear a "rushing" sound inside the car you have a leak.
Reservoir has only one job, buffer coolant as it expands and contracts (about 2% volume change from cold to operating temp). The radiator cap is what allows the back and forth based on temperature.
lexus-is2
May 2, 2022 02:48 PM
CUTEnanan
Dec 24, 2020 07:17 AM
gladiator6
IS - 1st Gen (2001-2005)
Dec 21, 2015 06:32 PM
Finn
Apr 13, 2014 05:35 AM
pongydoo
Nov 25, 2002 01:43 PM
