LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
2019 LX - Navigation/infotainment system random shutdown
Old Jan 27, 2022 | 06:18 AM
cssnms's Avatar
cssnms
Default 2019 LX - Navigation/infotainment system random shutdown
I am the original owner and over the last couple of years while driving the navigation/infotainment system would completely shut down. This has happened 3 times and each time it would come back up. It was almost as-if the system was rebooting.
Has anyone run into this issue?
Old Jan 27, 2022 | 07:10 AM
z32's Avatar
z32
best to bring back to the dealer for diag - still under warranty
Old Jan 27, 2022 | 08:41 AM
cssnms's Avatar
cssnms
plan to but I'm not optimistic they will figure it out. I suspect I'll get the typical "couldn't duplicate the problem' response.
Old Jan 27, 2022 | 03:07 PM
hankinid's Avatar
hankinid
"About 3 times in 2 years" means it will be difficult to duplicate. You may want to take a long ride or 3 with your service technician. I'd also suggest asking the question in the 200 Series section on ih8mud.com.
Old Jan 27, 2022 | 10:35 PM
ClaytonW's Avatar
ClaytonW
I have the same problems with my 2016 LX 570. I think that it's pretty common and all owners 2016 and newer LXs have similar issues. I worry that it cannot be fixed.
Old Jan 28, 2022 | 08:43 AM
z32's Avatar
z32
Maybe try turn off XM traffic / weather first and see how it goes. It would be best if you can record when the instance happens..how since it's so random it'll be hard to capture (not to mention the inconvenience). But try to go w/out XM traffic and weather first. Take note what was 'on' (in terms of the nav / audio / bluetooth commections etc) when it happens also. Process of elimination.
Old Jan 29, 2022 | 12:17 PM
cssnms's Avatar
cssnms
No ride with a technician will be long enough. 3x is equivalent to a once per year event.
My biggest concern is this occurring after the warranty expires and the what-if scenario it decides not to come back on at all. Perhaps getting it documented now will prove helpful down the road post warranty expiration.
Old Jan 31, 2022 | 12:51 PM
jsch222's Avatar
jsch222
Our 2018 had reboots. My 2020 GS also had about 20 reboots since owning. Both were fixed by a firmware update to the nav system. I haven't had a reboot on either since they updated.
Old Mar 30, 2022 | 06:39 PM
RebootIS's Avatar
RebootIS
There's a firmware update available via the Lexus portal that you can put on a USB. The change log on the update states it helps with the rebooting.
Old Mar 31, 2022 | 07:41 AM
Pathfnder's Avatar
Pathfnder
That's gonna be impossible to replicate for a service tech, I would think maybe a loose wire\connection somewhere.
I just cringe every time I get in my wife's '21 and have to use the stereo. I can't think of one positive feature other than it turns on. If someone came out with a plug and play replacement I'd be all over it.
Old Mar 31, 2022 | 05:27 PM
z32's Avatar
z32
If vehicle still under warranty and even if the tech cannot replicate the symptom, one thing the tech should perform is the check for software update availability.
Ybzjolan
HS 250h Model (2010-2012)
Jun 16, 2015 01:53 PM
