LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Long term storage
Old Sep 3, 2018 | 04:51 PM
lex97h's Avatar
lex97h
Default Long term storage
So I am ready to store my LX570 for a long time. Probably over a year. I disconnected the battery, rotated and inflated all the tires to 45 PSI. Set the suspension to normal height. Changed the engine oil. Is there anything else I am forgetting?
Old Sep 3, 2018 | 06:42 PM
DocT's Avatar
DocT
Gasoline stabilizer, and put the truck on the 4 racks.
Old Sep 4, 2018 | 09:19 AM
REDHORSE's Avatar
REDHORSE
Personally, I would leave the battery connected, but even if you chose to disconnect the battery I would attach a C-Teck battery maintainer.
https://smartercharger.com/
Old Sep 9, 2018 | 07:50 AM
Max707's Avatar
Max707
Crush a few bags of moth ***** around all the tires keep vermin away. Agree top off the battery keep it hooked up and put a trickle charger on it also if you put it on Jax’s it will keep your tires from flat spotting
Old Sep 9, 2018 | 08:40 AM
lex97h's Avatar
lex97h
According to the manual, the battery should be disconnected if trickle charging to prevent damage to the electronics. So I will trickle charge the battery with the terminals disconnected. I will also put fuel stabilizer in the tank to prevent the fuel going bad since it will be stored for quite some time. I've read somewhere that the hydraulic suspension might be damage if the truck is on jack stand for long term. Reason being, the shock now has to suspend the heavy wheel and it might cause a leak. The tires has been aired to 45 PSI to prevent flat spot. But if no damage will occur with it on jack stand, then I might go that route. Is there anything else I need to do other than the aforementioned items?
Old Sep 9, 2018 | 10:08 AM
REDHORSE's Avatar
REDHORSE
You don't want to "trickle charge." You want a maintainer such as the one I provided a link to. I've used various C-Teck on Porsche, Audi, Lexus, Chevrolet, Tractors, and lawn mowers for years and have
achieved extraordinary battery life.
Old Sep 9, 2018 | 07:27 PM
lex97h's Avatar
lex97h
What's the difference between trickle charging and a battery maintainer?
Old Sep 12, 2018 | 04:29 PM
REDHORSE's Avatar
REDHORSE
Not an expert, but basically maintainers do not supply an uninterrupted current. They are "smart" in that they measure battery voltage. Trickle chargers supply a constant flow of current as long as connected, resulting in overcharging the battery.
worker
Mar 22, 2025 02:26 AM
lester123
NX - 1st Gen (2015-2021)
Apr 24, 2019 08:17 PM
intellis
May 12, 2011 03:41 PM
bob2200
RX - 1st Gen (1999-2003)
Aug 4, 2010 05:03 PM
gurjot
Jul 1, 2008 04:49 PM
