LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Removing and replacing side mirror on 2015 LX
Old Aug 7, 2018 | 07:45 PM
Bhebert449's Avatar
Bhebert449
Default Removing and replacing side mirror on 2015 LX
We have identified the cause of wind whistling noise in the driver side cabin is due to a missing gasket where the driver side mirror attaches to the door. I ordered the gasket and plan to install the gasket myself. My question is how difficult is it to remove and replace the mirror? I assume there is a piece of trim that covers the bolts that attach the mirror? Any thing I should be away of or is it pretty straight forward?
Old Aug 7, 2018 | 08:56 PM
hzhao's Avatar
hzhao
25 Year Member
I assumed the gasket that you are referring to is a soft piece rubber kind triangle shape that goes on to the mirror house between the door frame and mirror housing, right? to replace that is fairly easy, if I am recall correctly, just one small tapping screw near the lower triangle frame, then just pull it out with soft taps. most works are taking the door panel off, disconnect the mirror control harnesses, there are three bolts hold the mirror assembly. There is also a weather seal tape one the gasket where the harness cable goes into the mirror that needs to be removed before you can take gasket off. Rest of are easy.
Old Aug 7, 2018 | 09:03 PM
Bhebert449's Avatar
Bhebert449
So do I have to remove the door panel or just the one screw under the triangle?
Old Aug 8, 2018 | 04:42 AM
hzhao's Avatar
hzhao
25 Year Member
You have to remove the door panel in order to disconnect the wires. There are three screws under the triangle cover.
Old Aug 10, 2018 | 08:16 PM
Reggie1's Avatar
Reggie1
Part of this video may be helpful. I used it when I installed my towing mirrors.
Apothist
Jul 2, 2018 11:04 PM
maxx430
Oct 20, 2014 01:23 PM
daveskates
Jun 25, 2013 09:30 PM
LEXuriouss
Jan 22, 2007 12:46 AM
