LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Buzzing Hissing Noise?
Old Oct 27, 2016 | 10:15 AM
JT4's Avatar
JT4
Default Buzzing Hissing Noise?
My neighbor has a 2013 and when the weather turns colder he gets a buzzing / hissing type of electrical noise (if this makes sense) that is coming from behind the Nav / Infotainment screen. It usually only happens after the initial morning start-up. He hasn't had the noise since last spring, but now that the last couple of mornings the weather has been colder (low 40's overnight) when he starts it up in the morning the noise is back.
I heard it this morning and it's not the blower / fan motor because I had him turn off the HVAC system, but the noise was still there. Drove for about 10 mins and the noise goes away when it warms up.
Just wondering if anyone has experienced this or something similar.
Old Oct 30, 2016 | 08:14 PM
teambell's Avatar
teambell
8th Gear
I just experienced, what seems to be a very similar thing. The "white noise" like sound seemed to be coming right from the front center part of the dash. I found the source to be the ventilated seats, when I turned them to off, the sound went away immediately. This was a 2009 model and I was doing a test drive...
Old Oct 31, 2016 | 05:38 AM
JT4's Avatar
JT4
Thanks for the response, and yes I guess you could consider it the be similar to "white noise". However, it has nothing to do with the ventilated seats because when the seats are off the noise is still present.
The noise only occurs when the temp outside drops, so basically once the temps drop into the low 40's (or lower) the noise re-appears. For example, the last two days the temps were back in the 60's and the noise wasn't there.
Again thanks for the suggestion...
Old Oct 31, 2016 | 06:41 AM
ttomasic's Avatar
ttomasic
try turning the Heating/Cooling system to full OFF and see if this persists. Maybe it is in the AUTO mode to condition the interior space, and stops after the cabin is warm. Experiment with turning various systems off until you can isolate this.
Old Oct 31, 2016 | 10:02 AM
JT4's Avatar
JT4
Very strange because even when the the HVAC is off the noise is there, turning the HVAC on / off does nothing. Sounds like it's coming from the area behind the Nav screen.. Going to keep trying to trouble shoot since so far he has no luck with the dealer.
Thanks for the suggestion..
rns
Hybrid Technology
13
Mar 31, 2023 07:42 PM
lxus2001
RX - 1st Gen (1999-2003)
Jun 17, 2019 09:27 AM
pinoiryder
Feb 7, 2011 09:50 AM
kingbailey
Aug 31, 2008 12:13 PM
ChrisM910
Apr 25, 2006 01:41 PM
