LX570 2015 Wind whistling
I'd be astounded if it goes away. No whistling with oem wipers on my 200 and that includes oem wipers, Michelin, and Bosch Icons which I finally settled on. I'd be looking at the luggage rack and general windshield installation. Does your truck have its original windshield?
I will try to move the luggage rack and circle back.
It took me two tries to find a quiet spot for the cross bars, so if at first it doesn't work, suggest you try again.
hth
Steve
hth
Steve
Toyota had to issue a tsb for the 100 series roof rack related to noise. Each cross bar needs to be at the end of it's travel...i.e., front bar as forward as possible and rear bar as far to the rear...cross bars are installed so that the narrow side of the bar airfoil points forward on both. Maybe something to try.
hth
Steve
hth
Steve
Quick Update, I have moved the ski rack all the way to the back and no more whistling noise. Thanks a bunch for you help on this!
Bumping this thread as I am new to the forum and am a new owner of a 2015 LX 570. I am noticing wind noise at highway speeds from the driver side.
i looked at the position of the cross bars on the luggage rack and the front is in the forward most position and the rear in the rear most position. Should I push the front cross bar more to the rear? Is another possible cause the gasket around the windshield?
Leave the front cross bar as far forward as you can and leave the rear cross bar where it is. Make sure the thicker side of the bars point forward.My glass guy recommended a slightly different gasket across the top of the windshield. It's identical to OEM except the top of the gasket extends about 3/8" more toward the rear. Ask your local dealer who does their glass replacement and call that person and ask. What does the DOT label say in the lower front corner (could be left or right side) of the windshield?
The DOT label says DOT 459. Here are a few pics. I looked at the gasket where the windshield meets the roof. It appears to be a bit irregular. Also what about the trim on the roof above the door. Is there supposed to be a gap there? It is the same on both sides.
hth
The molding on the sides of the ws that extend onto the top about 6-8 inches should have NO gaps. The last ws install was in my driveway by the guy that does most of the high-end cars and trucks (Land Cruiser, LX, MBZ, Porsche, etc.) locally. He spent a lot of time pre-bending those moldings to have a perfect curve and lay flat against the roof. If yours are proud of the roof by a little, you can try a bit of silicone gasket sealer to keep them down. Clean the roof area and underside of the molding as best you can with a gentle solvent like naphtha (aka Coleman fuel or lighter fluid), apply silicone to the molding, push it against the roof and tape it in place...I'd suggest gaffer's vs duct tape as it leaves little if any residue when you pull it off. Install it early in the morning and let it bake in the sun for a full day. Remove the tape and you are good to go.
hth
hth
I'd guess dealer's service manager will address it with whomever does their...I've never seen a dealer with a captive glass operation in the service area...too much of a specialty.
