LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
trailer hookup question
Old Mar 6, 2023 | 07:25 PM
  #31
hankinid's Avatar
hankinid
Thumbs down
Originally Posted by lexusrus
I'd avoid anything electrical from Harbor Fright...you get what you paid for. Cheap Chinesium is not, imo, what you want.
Old Aug 22, 2023 | 10:54 AM
  #32
Bgw70's Avatar
Bgw70
Veteran: Air Force
Originally Posted by hankinid
If your truck was sold with a towing package, the harness which connects to the truck and trailer was supplied in the left side 3rd row seat. Pull down the zipper in the back and see what you find. if you can't find the harness, you can get one online via a dealer or other source of Lexus parts.
hth
I looked all over the left third row seat and cannot locate the zipper.
can you post a pic please.
Does the seven to four pin adapter come with the LX570 or is it a separate purchase?
I just ordered this one from Amazon
Old Aug 22, 2023 | 11:38 AM
  #33
Bgw70's Avatar
Bgw70
Veteran: Air Force
Here are the items that came with my 2020…the dealer did not install the trailer plug or wiring.
Receiver Hitch, no ball
Trailer Brake Harness, I assume it is for the controller.
7pin trailer plug
Old Aug 22, 2023 | 06:24 PM
  #34
hankinid's Avatar
hankinid
Easiest if you drop the tailgate and lift up the rear window so you can get in there.
Look at the driver's side 3rd row seat. You'll see a seam centered on the rear of the seat.
At the top of the seat is a zipper control. Pull it down all the way, stick your hand in the opening, and see what you find.
Beyond simple.
Old Aug 23, 2023 | 12:09 PM
  #35
Bgw70's Avatar
Bgw70
Veteran: Air Force
Beyond simple.
thanks for the help…I found the third row center headrest.
Old Aug 24, 2023 | 11:21 AM
  #36
Bgw70's Avatar
Bgw70
Veteran: Air Force
Installed the trailer electrical plug this morning.
about a 10min job
used a 12mm socket.
NOTE: remove the dust caps on the truck connectors.
I sprayed all of the connectors with contact cleaner, then applied dielectric grease.
used Never Seize on the bolts and plug bracket to truck frame mount.
Old Aug 24, 2023 | 11:49 AM
  #37
Bgw70's Avatar
Bgw70
Veteran: Air Force
Looks like a good storage place for the 7-4pin adapter
Old Sep 28, 2023 | 10:32 AM
  #38
SC3coupe's Avatar
SC3coupe
Have you figured out what this one in the picture is for? I have the 7 pin plug installed on my car but don't know what this white one is..
My GX is 16 years older and also have what looks to be exact same thing in the glove box
vipers5397
GX - 1st Gen (2003-2009)
17
Jun 12, 2024 02:10 PM
tdott
RX - 3rd Gen (2010-2015)
29
Apr 26, 2021 09:03 AM
clickart
GX - 2nd Gen (2010-2023)
Mar 24, 2017 08:24 PM
bobcindy
Oct 29, 2004 09:25 PM
