LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Alignment issues
Old Feb 2, 2026 | 01:35 PM
benandaliza1243's Avatar
benandaliza1243
6th Gear
Default Alignment issues
Hi
i’ve brought my 2018 LX 570 to the dealership five times to fix the alignment as the car pulls to the right when I let go of the steering wheel. It is so frustrating to have to hold the steering wheel down just to make sure it doesn’t go right
The dealer has done an alignment five times and they don’t know how to fix it. Any ideas?
Old Feb 2, 2026 | 04:31 PM
Ratchey's Avatar
Ratchey
Have you rotated the tires between any of these alignments?
Old Feb 3, 2026 | 09:15 AM
benandaliza1243
6th Gear
yes I rotated them
Old Mar 4, 2026 | 06:56 AM
benandaliza1243
6th Gear
yes
Old Mar 4, 2026 | 07:47 AM
Ratchey's Avatar
Ratchey
Originally Posted by benandaliza1243
yes
Does the alignment come back within specs or is it out of spec and they say they can't fix it
Old Mar 14, 2026 | 08:37 AM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
I would try a local shop w/ a good reputation to do an alignment. Just because you go to the dealer doesn't necessarily mean the know what they are doing. Especially 5 times! Ask for the computer print out w/ the before & after repair specifications. (Green is good Red is bad) Make sure the Time, Date & VIN or License plate number matches your truck and not someone elses.
I would also try cross rotating the front tires to see if the pull changes to the opposite side if the alignment doesn't take care of the pulling. The belts in a tire can take a "Set" & create a pull in a specific direction, swapping to the other side with no change can rule that out. I know you said they did rotate the tires, but lazy Techs just swap them front to back & not cross rotating them like they are suppose to.
Old Mar 16, 2026 | 07:01 AM
sfuad's Avatar
sfuad
I would agree with these recommendations. Just make sure whenever you take in your vehicle for alignment, turn off AHC. For some reasons if
ahc is on, it lowers the car and we don't adjust it properly.
nkseto
Jun 27, 2020 07:39 AM
maximakid
Mar 11, 2013 04:48 PM
Och
Apr 2, 2012 02:04 AM
garfull
RX - 3rd Gen (2010-2015)
Jan 20, 2011 02:25 AM
RacerLex
Dec 13, 2006 04:33 PM
