LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
4x4 light flashing ?
Old Sep 4, 2024 | 01:01 PM
psychodoc's Avatar
psychodoc
Default 4x4 light flashing ?
Seems like ~every 10th time I start the car the 4x4 light is blinking.
Can't find a way to turn it off.
pushing the button w/the same 4x4 picture does nothing
No change in the way it drives...
Old Sep 4, 2024 | 08:57 PM
Ratchey's Avatar
Ratchey
How often do you engage 4wh drive? You should be doing it every month or so and driving for a mile.
It could be the actuator getting stuck, especially if you have difficulties shifting into 4wd.
Old Sep 5, 2024 | 05:41 AM
implantgs4's Avatar
implantgs4
Could be your battery is starting to go and has lost enough reserve capacity, so when you start the car there is not enough "juice" to test the solenoid for the transfer case. Happened to me with my GX470, and new battery solved the problem. Have the battery checked to make sure it is within specs and has reserve capacity.
Old Sep 6, 2024 | 10:24 AM
mfeferman's Avatar
mfeferman
It’s the actuator for the system to shift from 4H to 4L. Increasing usage doesn’t do anything to prevent this. In Houston, where is very hot and humid, it’s happens in the morning, but when I drive the car for a bit and then turn it off/turn it back on, it’s fine. The transmission and that part have heated up and the moisture is gone. There are some videos on YouTube of people taking it apart and fixing the metal contacts and applying more dialectic grease. It seems that the POST is failing with moisture as these age and the grease wears off. In one of the videos, it seems like there was arcing across the metal strip and the contact point.
Old Sep 7, 2024 | 03:49 PM
psychodoc's Avatar
psychodoc
Thanks... I'm in the FL Panhandle & I think this may have been a Texas car...
Is it hard to get to the actuator ?
Cw050621
RX - 1st Gen (1999-2003)
May 2, 2021 08:05 AM
Peter5767
Jan 12, 2011 11:34 AM
DVac3
Feb 8, 2008 01:09 AM
southtrian
Mar 21, 2006 08:05 AM
