LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Power antenna
Old May 18, 2021 | 11:19 PM
CosmicOne's Avatar
CosmicOne
3rd Gear
Default Power antenna
On the verge of buying a 2006-2007 LX 470 and am wondering about the reliability of the power antenna. Are they likely to fail with normal wear? Are they expensive to replace?
Thanks in advance.
Old May 19, 2021 | 04:57 PM
hankinid's Avatar
hankinid
Thumbs up
Thanks in advance.
They wear out sooner or later. Issue shows up as hesitation or failure to move antenna, The antenna mast is moved via a nylon flat gear about 2.5 feet long. The flat gear never breaks, but the toothed side wears out as the gear teeth wear. It's easy to repair (10 minutes, less if you've done one before). You'll need a tool to remove the nut on top of the fender mount. Once that's gone, power the antenna up while holding the end of the mast. Stop when the end of the nylon cable is free of the truck. Reassemble in reverse order.
Video's on mud...100 Series Antenna Installation
If you don't feel like replacing it, move it manually up or down. 30 inches is cut for the middle of the FM band.
Bankswood
Jun 15, 2014 12:02 AM
SpencerT
13
Mar 24, 2012 07:59 AM
MrBrock
Jul 10, 2010 11:48 AM
