LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Rock vibration?
Old Dec 5, 2006 | 04:08 PM
LXotic's Avatar
LXotic
Default Rock vibration?
do you ever hear a funny sound after you shut off your LX?
I do I hear like rocks popping coming from the Lx470.
It goes on for like 5min. max. Is this normal?
Help would be greatly appreciated
thanx, Jacob
Old Dec 5, 2006 | 04:25 PM
sdbrandon's Avatar
sdbrandon
thanx, Jacob
Are you referring to the metal cooling/flexing/expanding/contracting once the engines turns off? That is normal.
Old Dec 5, 2006 | 04:41 PM
aedgington's Avatar
aedgington
Have you checked your manifolds?
Old Dec 5, 2006 | 04:54 PM
LXotic's Avatar
LXotic
would it be because the manifolds are cracking?
Old Dec 5, 2006 | 06:29 PM
aedgington's Avatar
aedgington
Normally you hear it on starting, clicking & popping that gradually goes away as it warms up. It was just a thought off the top of my head.
In answer to your question, though, yes, because the 100 manifolds are notorious for cracking.
Old Dec 5, 2006 | 06:49 PM
LXotic's Avatar
LXotic
well I was talking about AFTER you shut the car off.
Does the dealer check for you if your manifolds are cracking?
If they are, how much would it be to replace?
thanks, Jake
Old Dec 5, 2006 | 09:03 PM
V8_Fan's Avatar
V8_Fan
I'm pretty sure it's the exhaust/emissions system. It does that on my '01 honda (but not on my 86 4runner...too old for the fancy emissions stuff like dual cats/mufflers). If it clicks when you turn on the engine (engine cold), it's likely cracked exhaust manifolds=$$$ to replace. My theory is repeated short trips where it's cold outside, then the metal warms, then cools suddenly is bad on the manifolds based on the metal its made from.
Old Dec 6, 2006 | 11:51 AM
LXotic's Avatar
LXotic
so would the dealer be able to replace it for me and how much $$$ will it cost??
Old Dec 6, 2006 | 01:37 PM
V8_Fan's Avatar
V8_Fan
Replace what? You indicated that your vehicle makes that sound AFTER you turn OFF the engine. That's normal, nothing you can do about it other than completely scrap the emissions system. The cats get very hot to burn off the emissions that would otherwise be released into the air.
Old Dec 6, 2006 | 06:26 PM
LXotic's Avatar
LXotic
o all right then *whew*
Apr 24, 2018 11:59 AM
TheCat1
May 22, 2011 07:23 AM
reyoasian
Jun 24, 2010 09:47 PM
Shaffer
Feb 12, 2004 09:26 AM
RinnDogg
RX - 1st Gen (1999-2003)
Jul 17, 2002 05:53 PM
