LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
wet cargo area
Old Jun 2, 2006 | 05:13 PM
chip99's Avatar
chip99
Default wet cargo area
hello after the recent heavy rain we had my rear cargo area was really wet mostly on the left rear (driver side and running along the bottm door hatch. the carpet on the door itself it dry and the rubber seal is dry on the outside so its definetly coming in some how from the inside possible drain plug clogged??? any ideas
Old Sep 30, 2009 | 08:31 AM
dan470's Avatar
dan470
Hi I am a new member hence the late reply to a 06 post. The leak
is caused by the top rear light, the plastic warps over time, Lexus
will charge $ 400 to replace easy fix clear silicone, And btw Lexus
will not admit the fault. I hope this will help anyone who has this
problem.
Old Sep 30, 2009 | 10:41 AM
Rollin'ES3's Avatar
Rollin'ES3
CL Folding 10,000
If that guys LX has been leaking since 06 that car is a flood damage vehicle by now....
Wonder if he ever fixed it?
Old Sep 30, 2009 | 05:01 PM
tromly's Avatar
tromly
problem.
That's great info Dan, thanks for sharing
Old Sep 30, 2009 | 08:08 PM
V8_Fan's Avatar
V8_Fan
I had this happen to me 3 yrs ago...very heavy rain, 40+mph crosswind. I don't think it could be the top rear stoplight since that would cause water to flow into the rear hatch. The wet carpet I had was just about where the driver's side rear D-ring is. I thought it might have been from water entering exterior rear quarter vent. I never figured it out, but it has yet to happen again, and I've been in a strong t-storm recently.
Old Oct 6, 2009 | 05:47 PM
dan470's Avatar
dan470
Light rain, heavy rain, hose pipe, its the rear top light. I have done the
clear sealant fix. No more wet cargo area.BTW the fix was told to me by
my Lexus service agent.
Old Oct 6, 2009 | 08:44 PM
V8_Fan's Avatar
V8_Fan
FWIW, I just had my rear top stop light replaced due to a crack about 1/3 of the way from the right side along the internal lens seam. FYI, that light has gotta be the most expensive 3rd stop light sold! Part alone is around $200! (compared to $90 on my LS430!). I looked at the original one and it has some kind of adhesive foam as the seal. The original foam was all chewed away.
Did you have to remove the stoplight to seal it, or did you just caulk around the outside?
Old Oct 7, 2009 | 10:15 AM
dan470's Avatar
dan470
I removed the light and put the sealant where that old foam stuff
used to be light side and body side replaced the light and then sealed
the outside, I used a razor like a putty knife on the outside works
great.I Would like to take credit for this great fix but it was my service
agent who told me how.The problem first appeared in the Arab stats
the extreme heat causes the light shrink, Lexus and LC have known
problem for years,Florida Arizona same climate.Hope this helps.
Old Feb 15, 2020 | 05:10 AM
davidlt's Avatar
davidlt
10th Gear
Mine was caused by bad rear weather seal around cargo opening. Replaced and no more leaking.
Old Mar 1, 2025 | 11:20 PM
ChasAdams's Avatar
ChasAdams
2nd gear
Default Seal for back hatch
Davidlt, Did you replace that seal yourself or have it done? I looked in to it and the new seal is expensive!
Old Jan 9, 2026 | 07:26 PM
davidlt's Avatar
davidlt
10th Gear
Same here years ago, replaced seal on upper tailgate, dry since.
ssmeev
May 11, 2017 11:55 AM
dbs600
Jan 14, 2016 11:19 AM
wrencher73
Mar 31, 2015 09:59 AM
gage
Aug 20, 2010 06:58 AM
O. L. T.
Jul 8, 2005 05:38 PM
