Anyone removed LS460 headunit yet?
Old May 10, 2009 | 10:04 AM
AlMuhairi's Avatar
AlMuhairi
Default Anyone removed LS460 headunit yet?
Hello everyone,
Has anyone took apart their LS460 headunit and screen? I have been looking for instructions on how to take apart the side panels and headunit with the screen but didn't find anything.
I would appreciate it if someone could guide me through it.
Old May 12, 2009 | 06:38 PM
bruceko's Avatar
bruceko
It is a secret. No one one the Ls forum wants to tell anyone. If this had been a Gs forum you would have had 10 answers by now.
First take off the side panels. Just pull out at the storage compartment end.
Second pull up and out on the ash tray.
Third remove the two bolts holding the head unit.
These were a ***** for me to find and get out.
Where the side panels where hinged into he console by the ashtray you will see two small holes. the bolts are up above those holes at a slight angle. I had to enlarge the holes to get an extension in at the angle needed to get to the bolts. I think they are 10mm bolts.
Once you have got them out gently pry out the head unit.
Old May 13, 2009 | 04:34 AM
AlMuhairi's Avatar
AlMuhairi
thanks bruceko, that helps. I found some information on that too. check the attachment.
Old May 13, 2009 | 04:36 AM
AlMuhairi's Avatar
AlMuhairi
check this one too
Old May 13, 2009 | 04:39 PM
uae's Avatar
uae
May i ask why would you want to do so ?
Old May 13, 2009 | 05:15 PM
bruceko's Avatar
bruceko
You got it.
Sorry
it has been awhile since I opened mine up.
I forgot about popping up the box panel
Old May 15, 2009 | 08:52 AM
AlMuhairi's Avatar
AlMuhairi
UAE,
I am taking apart the headunit to install my mediaplayer to stream music through the navigation screen. It is the best option for me. I hate ipod the interface used to connect to the navi is blocked with the car is in motion, I hate ripping CD's all the time with at least 30% of my favorite songs are in at least 3 CD's. It is convenience and I love to take apart my car. You should see my previous car without the dashboard and seats :P....
Old May 16, 2009 | 06:34 PM
uae's Avatar
uae
I c , theres a device out there V2LC something like that, its plug N play and you connect that to the ipod. Sound Quality will be same as ipod depending on the Audio Bitrate , etc..
Old May 17, 2009 | 04:54 AM
AlMuhairi's Avatar
AlMuhairi
I know about it, the problem is you will need the device from prestige society to override the navigation lockout which will cost me alot. With the navtool, it is easier and much cooler because I can connect and Audio/Video selector in case I wanted to add more sources and extend the video playback to the rear screens
Old May 25, 2009 | 04:14 PM
uae's Avatar
uae
1- I still Dont know what your trying to achieve.
2- I think youre mixed up between the override and what i meant. What i meant is this:
http://www.vaistech.com/sl2vi.php
3- Prestiegious device isnt that expensive for UAE ppl , its like 1000 DHS Tops.
4- Rear PlayBack is Video/Audi Enabled 24/7 whether you have the prestegious device or not.
Old May 25, 2009 | 04:55 PM
AlMuhairi's Avatar
AlMuhairi
i know "uae", but my lexus is a US version and I dont have a rear display, im fabricating a custom rear entertainment center controlled from the front. I know what you are talking about, but its not what I am looking for ....you'll see what I mean later on.
Old May 25, 2009 | 11:48 PM
uae's Avatar
uae
I see your car is a US Model.
Congrats on the extra HP xD
Thanx for clarifying things,
Good Luck & Im waiting to witness pictures ;-)
Old May 26, 2009 | 02:02 PM
G-SharK's Avatar
G-SharK
Removing the head unit is easy, takes about 15 minutes. 6 screws and pop off's, that's it. Don't forget to disconnect the negative battery terminal before starting the removal process.
Old May 27, 2009 | 03:02 PM
AlMuhairi's Avatar
AlMuhairi
Hey new to IS3, i always do that whenever I am disconnecting a wire terminal or harness, learned my lesson when I burnt the soundcard on my pioneer navigation system once :P
Old Aug 3, 2009 | 02:05 PM
AlMuhairi's Avatar
AlMuhairi
OK. I took the initiative of taking apart my headunit using these steps:
Took the side panels out, then took the center piece at the center console, unscrewed the gear ****, took the gear shift assembly out after removing the two screws on the left side, took the ashtray out and disconnected the cigarette lighter, then removed the two screws on the sides to remove the DVD changer and pulled it out without disconnected the harnesses with the gear shifted in neutral.
Then shifter the gear back into park after moving the DVD changer out of the way and turned the car off. I left the car turned off for about 10 Minutes (IMPORTANT). Then disconnected the negative terminal and went to remove the harnesses for the DVD changer, and then removed the two screws inside that hold the navigation unit and pulled it slightly out.
I connected NAVTOOL according to the diagram and and installed it just fine.
The problem was that the NAVTOOl did not work, I tried 4 different video sources but none of them work!!
I want to know if I did something wrong or something
If anyone installed NAVTOOl device I would love to hear from them.
Kee318
Mar 14, 2019 05:40 PM
joedaddy1
Jan 2, 2017 06:19 PM
kimsake
Feb 23, 2016 10:15 PM
CashOverAs
Jul 26, 2011 04:52 AM
