Has anyone removed 6 CD Player/Replace with Single DIN
Old Feb 5, 2011 | 10:24 AM
Jacks's Avatar
Jacks
Default Has anyone removed 6 CD Player/Replace with Single DIN
Hey Guys,
I want to upgrade my '01 LS430 Ultra to have today's features of of XM/Sirius Radio, Bluetooth to play music from mobile phone, Speakerphone, Front USB Input, etc.
Without tearing apart the dash to find out I'm wrong, I wanted to air this out and see what you Lex-perts thought of the idea.
Here it is:
The 6 cd changer appears to be single-DIN. If I swap out the CD changer for a loaded single-DIN Car stereo (Crutchfield has a ton) with all the bells and whistles and it has the pre-outs to hook into the factory installed system CD input, I should just have to push the "CD" button on the dash and have all the functionality I am looking for, less the FM radio, which I would already have in the main unit. Right?
Here's my conerns:
1. The new radio would need be very flat faced so the front panel can still close and keep the original appearance of the interior?
2. Would simple 2 channel pre-outs with RCA connections hook into the main radio. Has anyone pulled it seen how the CD changer is attached to the main radio?
3. Would RCA connections even work or do I need to splice wires?
4. Are 2 channels enough as they do sell single-DIN's with 2, 4, 5 pre-outs?
The idea seems quite simple, but it seems too simple. What am I missing? Look forward to your ideas.
Thanks.
Old Feb 5, 2011 | 11:51 AM
vadorade's Avatar
vadorade
I plan on doing something like this...
http://www.youtube.com/watch?v=X8_bHBpoNb0
Old Feb 5, 2011 | 03:09 PM
Jacks's Avatar
Jacks
Now that's what I'm talking about! Where can I buy it?
Old Feb 5, 2011 | 10:14 PM
vadorade's Avatar
vadorade
I think this was custom made in Japan... so not sure if you can buy it. I will rig it up myself with the help of a friend. will keep ya updated. I like the idea of having the single DIN/screen hidden when not in use to deter theft, and replacing the CD changer is perfect for this.
Old Feb 6, 2011 | 05:00 AM
sojah's Avatar
sojah
first thing i noticed was the volume and tune were flipped around backwards but then i noticed the steering wheel on the right hand side, therefore i guess they put the volume closest to the driver.
looks nice good luck.
Old Feb 6, 2011 | 08:02 AM
GLIDESUL's Avatar
GLIDESUL
That's big boy style there
Old Feb 7, 2011 | 06:26 AM
LexusJoey's Avatar
LexusJoey
That is SICK !!!!
Old Feb 12, 2011 | 09:02 AM
Jacks's Avatar
Jacks
I'm hoping to pull something off a little more realistic like this one off using VAIS Tech and just using the pre-outs on the aftermarket radio.
I should get XM, Bluetooth, HD Radio, USB input, IPod connection, etc.
Attached Thumbnails Has anyone removed 6 CD Player/Replace with Single DIN-clarion-ls430.jpg
Old Feb 12, 2011 | 09:17 AM
vadorade's Avatar
vadorade
Jack, I saw this picture too and thought about going that route but saw a feel problems. Modification of stock dash is still necessary because single DINs wont fit into the small slot on our ls430...the slot in the picture was cut on both sides in order to fit the radio. Also, it is very hard to find a radio that is flat since most have a **** that protrudes out, making it hard to close the wood door. the radio in the video solves this problem.
Old Feb 19, 2011 | 04:22 AM
1stock06's Avatar
1stock06
Slight modding of the factory bay will be required. The flip down door can also be hollow-ed out. You can shave down the control **** shaft for more clearance. My ride is in the shop (rewire amp and speakers). I can post pics in a few days. Depending on the skill of the tech that will do the work, a day and a half to mod the bay and install the head unit should do.
The end product is truly worth it. It will look almost too stock.
Old Feb 19, 2011 | 08:54 AM
brio_ls's Avatar
brio_ls
Sorry if i'm missing something, but what did you do with the OEM CD changer? Did you extend the wires and hide it into the glove box or just removed it for ever?
Old Feb 19, 2011 | 01:23 PM
fergo308's Avatar
fergo308
The changer is usually binned. Vaistech uses the changer's connections and emulates the changer's function,but using your own input source. the car thinks it's playing thechanger,when in actuality it's playing your Ipod or whatever.
Justin...
Old Feb 19, 2011 | 03:58 PM
jayclapp's Avatar
jayclapp
The Vaistech SL2Vi allows either the existing or iPod to be selected and used. Selection is made my pushing the audio CD button. Pushing it again selects the alternate connection, iPod for instance.
Old Feb 20, 2011 | 04:29 AM
1stock06's Avatar
1stock06
the existing changer is removed. totally gone. you still need the factory radio control unit. (according to the Tech that did my install)
Old Apr 22, 2011 | 08:34 PM
agunjal's Avatar
agunjal
hi - were you able to post pics. I am going to try and make a single DIN fit as I have already removed my CD changer. Wanted to see if anyone else had any tips
