Massage Chair
Old Dec 18, 2024 | 10:24 AM
UsedLS500's Avatar
UsedLS500
2nd gear
Default Massage Chair
I have an LS500 with 32500 miles. I am experiencing some issues with the driver's chair. The massage has lost some of its power and you can hear the air seeping from the chair whenever thr massage is on. Has anyone else experienced this problem?
Old Dec 18, 2024 | 01:03 PM
LSNewbie's Avatar
LSNewbie
10th Gear
The problem you are reporting sounds like one or more of the air bladder(s), which are inflated and deflated to create the "massage" motion, are leaking. My 2018 LS500 has two bladders that go flat over time, but none that I can hear leaking. I'd say live with it unless it's worth the expense to you.
Old Dec 18, 2024 | 01:54 PM
Bigoofy's Avatar
Bigoofy
The control unit for the bladder pumps is incorrectly programmed. There was a recall/TSB on certain models. Ask your dealer, you may be eligible for replacement.
Old Dec 27, 2024 | 07:59 AM
LSNewbie's Avatar
LSNewbie
10th Gear
Bigoofy, Thank you. Do you happen to know the TSB number?
Old Dec 27, 2024 | 08:22 AM
Bigoofy's Avatar
Bigoofy
Unfortunately not. Maybe a search on this forum.
Old Feb 11, 2025 | 11:03 AM
smiley09's Avatar
smiley09
My 2018 LS500 had the same issues you noted with the massage function. I had the front and passenger side air bladders replaced, thankfully they were under warranty as they were pretty expensive, good luck
warnerca
LX - 3rd Gen (2008-2021)
May 7, 2025 05:54 PM
BabaSam
May 15, 2024 07:27 PM
salamanda2
LS - 5th Gen (2018-present)
37
Oct 15, 2023 10:20 AM
acantore
Jul 10, 2017 05:04 PM
icegoffy
Hybrid Technology
May 30, 2011 12:59 AM
