Rubbing noise from front passenger side while turning left.
Old Nov 6, 2023 | 12:22 PM
Jaynight's Avatar
Jaynight
Default Rubbing noise from front passenger side while turning left.
Have anyone experienced any rubbing noise from front passenger side while turning left? It does it at low speeds but not when the wheels are straight.
Old Nov 6, 2023 | 01:06 PM
PGA71's Avatar
PGA71
This should not happen unless you put larger rims and tires on the car that are specified or you lowered the car too much by changing springs or adding lowering links to air suspension to the point of rubbing.
If none of this is applies to you, you should have the suspension/alignment checked out which is most likely the reason.
Nalod's Avatar
Nalod
What year? Equipment? Miles on Odo? Original equip tires and wheels? F-sport? AWD? Suspension type? Is it an LS500?
Has anyone looked at it at a shop? Dealer?
Help us help you?
Old Nov 6, 2023 | 01:43 PM
Jaynight's Avatar
Jaynight
My car is a 2018 LS500 with Adaptive Variable Air Suspension and 20" 10 Spoke Alloy Wheels w Vapor Chrome Finish with 11k miles. I have not taken it to the dealership yet. Not a Fsport.
Old Nov 7, 2023 | 06:26 AM
Lingus's Avatar
Lingus
Brake backing plate
Old Nov 8, 2023 | 03:56 AM
sajack's Avatar
sajack
You didn’t say if you had runflats. I would start off by pulling the right front tire. Check it for any unusual wear. Then switch it with the right rear.
Old Nov 8, 2023 | 09:45 AM
dan25man's Avatar
dan25man
Why turn left when you can make 3 rights instead? No more sound. Problem solved!
Old Nov 8, 2023 | 10:39 AM
Jaynight's Avatar
Jaynight
Yes I do have runflats i will check the backing plate and switch the tires around. Thanks guys for giving me some starting points to troubleshoot this issue.
Old Nov 8, 2023 | 01:53 PM
sajack's Avatar
sajack
I knew a guy who quit making left turns when he turned 85 years old. He would drive all the way around the block just to keep from turning left.
Old May 24, 2024 | 03:30 PM
Jaynight's Avatar
Jaynight
The inside wall of tire
The inside wall of the run flat was cracked which was making the rubbing noise.
I have taken them now the rubbing sound is gone
lextoys
LX - 4th Gen (2022-present)
61
Nov 9, 2024 02:01 PM
Carlito111
Suspension and Brakes
Nov 11, 2020 03:06 PM
Meego
Jul 29, 2010 08:27 PM
