I did front and rear pads and rotors in February. I compressed both front and back pistons with the car off, parking brake off, and no command from Techstream, all without incident. Not sure if I somehow got lucky, but everything worked, and continues to work beautifully. It was actually one of the easiest brake jobs I’ve ever done. I like the way it’s engineered.
You did get lucky on the rears, you actually forced the valves open when you compressed the fluid. Usually this pisses the system off if it sees backflow, good thing it didn't seem to notice this time lol!
I change my own pads, have done front and rear with no issues also, same way as Outofspec. Take old thinner pads out, use piston caliper spreader tool to push pistons back in, put new thicker pads in.
Did you guys remove the master cylinder cover prior to compressing the caliper pistons? Or no?
Doesn't hurt, and I also inserted a few shop towels just in case. More importantly, it is highly recommended the car not be on/started or brake pedal depressed during the rotor and/or pad replacement. Like others mentioned, I too was able to replace all 4 rotors and pads (>10k miles and 2 yrs ago) without having to use Techstream. With the proper tools (and elbow grease), no real need to turn the front wheels to replace those rotors/pads.
