I have a 2010 LS 460l with the right rear about 3/4 in lower than the rest of the car. I have tried to adjust it but it does nothing. I do not think it is the shocks because if i switch to high mode the whole car raises as it should. How to i check if the actual adjustment does not work. Air shocks on car
How did you try to adjust it? Have you taken measurements at all 4 corners at normal and height high settings for comparison to see if the differences are consistent in both?
Yes the passanger side is 1/2 lower than the right side. If i set it to high it raises up up equally still lower on right side. I know how to adjust it it just does nothing
