Vibration from front driver side
Old Jun 22, 2022 | 06:13 AM
EazyLS460's Avatar
EazyLS460
Default Vibration from front driver side
When I crank the car up at a cold start I hear vibration from front driver side and and low rpm’s. After the car has been running for a while the noise goes away and ideas? Also Slight jerking from car when I pull off quick at cold start only.
Old Jun 22, 2022 | 07:17 AM
swfla's Avatar
swfla
Is this a new symptom?
Old Jun 22, 2022 | 08:36 AM
EazyLS460's Avatar
EazyLS460
Just started this weekend
Old Jun 22, 2022 | 12:00 PM
swfla's Avatar
swfla
I'd run a fuel injection cleaner thru the gas tank first. You don't mention age or miles.
Old Jun 22, 2022 | 05:54 PM
EazyLS460's Avatar
EazyLS460
2010 LS460 156k miles
Old Jun 22, 2022 | 07:49 PM
swfla's Avatar
swfla
Plugs due at 100k, clean throttle body, clean 2 MAF sensors, fuel injector cleaner in tank. After the above is done, give the computer a few hundred miles to recognize the work done. If still a noticeable issue... It could also be the motor mounts and transmission mount. Possible at your miles. If worn or broken, they will emphasize cold engine "roughness" and a jerk when accelerating.
Old Jul 22, 2022 | 01:57 PM
EazyLS460's Avatar
EazyLS460
It turns out to be a driver side engine mount……😔. Will replace that when changes plugs and o ring seal.
hlu
ES - 7th Gen (2019-2025)
Apr 16, 2020 09:32 AM
pc1990
IS F (2008-2014)
34
May 14, 2011 07:19 AM
Gojirra99
Oct 28, 2006 01:10 AM
toy4two
Feb 21, 2006 07:27 PM
XeroK00L
Mar 18, 2005 09:17 AM
