View Poll Results: How do you exchange brake fluid?
Let the dealer do it
57.14%
Engine off, car off, key left in car, door closed, gravity bleed
0%
Traditional 2 person bleed
4.76%
Techstream/software bleed/dealer style DIY
33.33%
Some combination of the above
9.52%
Zero down repeatedly and use a fluid extractor
4.76%
Multiple Choice Poll. Voters: 21. You may not vote on this poll
Brake flush thread, how have you been accomplishing it?
Old Jan 1, 2022 | 02:24 PM
Originally Posted by swfla
Very informative and worrisome. It would explain why so many units require replacement. Lexus procedure doesn't produce a proper flush. Am I reading that right? Seeing those particles of debris with your own eyes convinces me that finding an independent shop who will comply with your procedure is my best bet. If not, is your procedure something I can do alone? No one to press the pedal for me. Would a vacuum type bleeder do the trick?
Yeah that would be my stance as it sits right now. I don't think they are really putting enough care into it.
You can't really do this alone easily, a vaccum type would work but the front bleed according to the TS procedure would need you to pump it and place a rod between the chair and pedal. Then you would go outside the car and open the required bleeder, close it, return inside and continue on. Use a soft ended rod with lots of padding to prevent damage to anything....
You will need techstream or something equivalent to perform repeated zero downs, I have not yet come up with a way to do this without it. I'm trying to see if I can figure out a way via the wiring diagrams to short out pins to open the valves.
It's not easy though since unpowered is closed
Old Jan 1, 2022 | 03:08 PM
swfla's Avatar
swfla
Thank you very much for your response. I think it'd be more of a certainty to get it done right as DIY like you stated. Getting Techstream and finding a neighbor isn't impossible for me, I just need to make it happen.
Old Jan 1, 2022 | 06:26 PM
swfla's Avatar
swfla
Striker, do you know if a standard subscription to Techstream will accommodate he brake flushing? It's $20/2 days vs $65 for professional subscription.
Old Jan 1, 2022 | 07:42 PM
I don't know, I don't have a copy of TS since my Autel does almost everything it can. I'm not a Toyota only shop so I need to be able to cover a lot of different brands. Sorry I couldn't help
LatinLS430
Mar 25, 2023 09:48 AM
mikezat
GX - 2nd Gen (2010-2023)
Jun 4, 2021 09:09 AM
quatman67
14
May 7, 2011 09:25 AM
valexus07
Nov 16, 2010 02:06 PM
sveet
Dec 27, 2006 07:36 AM
