Audio/Navigation display buttons backlighting problem
2010 Lexus 460 L. All the buttons circled in RED don't have backlighting. However, they all function. Any ideas? Thanks in advance!
I read in a previous thread that it's an issue that was covered under warranty - they replace the whole unit. My "DISC" button doesn't light up on my '07 LS.
No harm in asking your dealer if it's still covered.
There is a number of ways to fix the issue if warranty is not available:
- replace the unit
- replace PCBs holding LEDs
- replace failed LEDs
If replaced LEDS, make to replace even those that did not fail yet.
- replace the unit
It is 11 years old car (2010) and I doubt the warranty is still available. Replacing the whole unit is probably very expensive. Where do I find the part number for the PCB? I do have a soldering gun and replacing the failed LED might be the cheaper option. Do you have a link for where to buy the LEDs?
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
https://taninjdm.com/ Our Lexus LS430 Dealership
262-456-4147
Update: Just back from the dealership and found no warranty. The whole replacement unit (not even OEM) would cost $2600 + labor + tax...
We offer a repair service, which is sure to save you a ton!
2007 AND NEWER LEXUS LS460 INTERIOR SWITCH LIGHTING REPAIR
Starting around 2004 Lexus, Toyota, Honda, and other manufacturers switched from interior bulb lighting to LED. The idea was that LED lasted longer than simple bulbs that you could twist out and replace.
Unfortunately, we are starting to see complex LED failures in many interior switches, *****, and indicator panels. The solution is fine circuit board work, soldering, desoldering, and replacing many microscopic LEDs.
Aside from our repair service for automotive interior lighting, the only solution is to purchase a brand new switch from the dealer. These can run up to $250 or more per switch.
The last photo is from a customer's car after the lighting repair was complete.
We can repair all of the switch lighting inside Lexus LS460 models from 2007 to the present.
The price varies by the number of switches, but they all come with a lifetime warranty.
ClubLexus members get 5% off with coupon code "ClubLexus5"
The current turnaround time is 2 weeks.
__________________
262-456-4147
262-456-4147
May very well be too difficult for DIY. Although would be helpful to know if its the LED's failing or the soldering. I've noticed some the lights flickering on and off and some are dimly lit
