Coilover top mount seemingly flat?
Old Oct 24, 2021 | 12:38 PM
stopdrpnro's Avatar
stopdrpnro
Default Coilover top mount seemingly flat?
Finally getting around to dumping my air for coilovers. The coils aren't marked left /right and the top plates don't have near the angle that the oem struts have. I was able to get them installed flush and the ride is greatly improved. I did everything possible to keep the stock ride height but the geometry seems off. I know a little negative camber is typical but I'm getting noise from the tires. Would an alignment fix this?
'09 awd if it matters
Old Oct 24, 2021 | 03:17 PM
Anfanger's Avatar
Anfanger
If you changed ride height, make sure to check if you need to readjust control arm bushings.
Old Mar 15, 2024 | 03:30 PM
sgaba's Avatar
sgaba
6th Gear
Hey @stopdrpnpro!
I’m looking to get the Ceika coilovers for my 07’ LS600 and was wondering how they’ve lasted since the install.
Also were there any error codes on the dash from the install?
Thanks in advance man!
datstockls
Jan 10, 2025 12:35 PM
Wlpls430
Apr 11, 2020 01:44 AM
Sportskid1
Suspension and Brakes
Jul 20, 2013 04:46 AM
steezy
Mar 30, 2009 02:33 PM
Mr Jokster
24
Feb 6, 2009 10:11 AM
