Cheap Bulbs or Bigger Issue?
Old Sep 26, 2021 | 05:40 PM
perm1226's Avatar
perm1226
Default Cheap Bulbs or Bigger Issue?
Hey y’all first post here cause I’m a little confused.
I recently obtained an 07 460 at 108k
First issue I’ve had was the stock driver side headlight started going out intermittently. So, I ordered some cheap bulbs from Amazon and started new by replacing both.
Bout 2 weeks later driver side goes out again.
At this point I’m reading into it as well as thinking it’s the ballast. So to get by for the mean time since I drive a lot at night I kept the Amazon bulb on the passenger side (not the problem side) and replaced the drivers side with the old passenger side STOCK bulb.
Well, 2 nights ago.. the PASSENGER side (Amazon bulb) went out.
So is it safe to assume that I just had bad Chinese bulbs and not the ballast?
I’m assuming I’m correct just would like everyone’s input, thank you!
Old Sep 26, 2021 | 06:07 PM
Anfanger's Avatar
Anfanger
LS460 is allergic to majority of aftermarket parts stick with OEM or high quality parts.
Old Sep 26, 2021 | 06:31 PM
swfla's Avatar
swfla
Lots of low quality Chinese products out there. Amazon's compatibility selector isn't always going to be correct. Exterior lighting is critical as well as a top reason for police to pull drivers over. Also these cars are highly sophisticated, even basic systems can act up with an incorrect voltage or load. A good way to sometimes save money is to buy from Toyota instead of Lexus if the part number is the same. Also, upgrading bulbs from incandescent to led can be tricky. Do a search on this forum before making any changes.
Old Sep 26, 2021 | 10:06 PM
perm1226's Avatar
perm1226
would you be able to recommend anything apart from oem?
Old Sep 27, 2021 | 03:42 AM
lexus13dan's Avatar
lexus13dan
Never buy from amazon, In my experience cheap sometimes used parts
Old Sep 27, 2021 | 04:09 AM
lwphat66's Avatar
lwphat66
It's often a gamble with cheap bulbs, so if you're going to go this route, I would search for threads where members have found some that seem to work well in their application. For the D4S bulbs, I personally would look into Osram, Morimoto, Philips, Sylvania. Whenever I can find the time, I'm installing the Morimoto XBs in 6000k as headlight bulbs/lighting is one of those areas where I prefer not to buy/rely on the cheap.
D4S: Morimoto XB XenGreen Bulbs 4500K-6500K Hues MM.N.069 (morimotohid.com)
starstreak
Oct 3, 2018 01:45 AM
Greer26
Dec 20, 2016 10:08 AM
merkin110
Jan 5, 2016 05:04 PM
ake11
IS F (2008-2014)
14
Aug 2, 2013 07:01 AM
cknjohnny
Jan 28, 2010 05:07 PM
