Abnormal wheel movement and vibration
I'm shopping now for oem lower forward arms cause i don't believe there's a bushing kit available for awd.
https://www.rockauto.com/en/catalog/...m+bushing,7532
Are you aware of the Suspencia pieces at Rockauto. There are no pics provided on this items but I ordered a pair anyway...Arnie
I’m one year into my RWD 2010 460. Here’s front end works done: All control arms, tie rods, sways, struts, ball joints, rotors and pads. I’m still getting the slight vibration at 60-75 mph and the rotors also warped after 5 months. So I just went OEM pads and rotors last week because the warped rotors were painful.
Here’s what I found. While installing the rotors everything went smooth, however why they decided to go with floating rotors and not a retaining screw escapes my mind. I then install the rotor and because I wanted a flush smooth install, I hold the rotors on with 5 lug nuts to obtain a flush pad install. I turn the rotor and look down the line before the pads go in and I notice there is an ever so slight wobble from the rotor. Take it off and reinstall, same thing. Determine Wheel Hub has slight wobble so bearings are going. I haven’t changed them yet, but my guess is that it will solve the vibrating issue and rotor warping.
Check the Hub.
Check the Hub.
Check the Hub.
Check the Hub.
Anyone want to chime in on what would cause the wheel to move side to side and vibrate when going over cobble stone ?
yes there’s some clunking and rattling, I had the tires checked, 2 of them needed to be remounted, however something is still not right I can’t put my finger on it.but it’s all much noisier than before I made my summer vacation trip I had the suspension tested on one of those machines Where’s they move the car and suspension they can’t find anything wrong…
Hub don’t last forever right? I think it’s never been changed might be a good time to change I hear koyo are just like oem and only cost a bit more than 100 usd per side which is 1:2 what toyota costs any comments on koyo ?
I had clunking issues when going over bumps. Replacement of front lower rearward control arms resolved the issue for me. Visually the bushings had no cracking or other issues.
I used OEM hubs when I replaced front hubs. I think, Koyo hubs are going to be OK as Koyo is an OEM supplier.
Was anyone able to figure out the cause behind this vibration/clunking noise?
2014 AWD Fsport - I’ve replaced front shocks, both lower control arms, sway bar links, and wheel hubs. Everything in pairs and everything is oem.
I get a very light “bouncy/wobble” feeling on driver side front when accelerating from 5mph up to 10 mph. Then the vibration is back at 50-70mph range. I’ve got brand new tires and balanced.
Also when I turn to the right the car feels it’s leaning more over to driver side. Does not happen when turning to the left.
there’s also a clunking/rattling sound coming from the front over light bumps.
Does the body roll improve when the setting is sport+... rattling and clunking could be from any of the usual suspects, I'd have a close look at the upper arm b-joints first.
derukun
May 16, 2021 03:18 PM
Grantville
Aug 27, 2010 08:53 PM
gsCrazy
Suspension and Brakes
14
Apr 11, 2009 09:32 AM
