Need help Please! 09 LS460 RWD Power Steering?
Old Jul 30, 2021 | 10:24 PM
Gennady7's Avatar
Gennady7
Default Need help Please! 09 LS460 RWD Power Steering?
Hey guys,
I have a RWD without air 2009 LS460. After being in a horrible accident in January and just finally having it fixed, I drove my gf home and somehow managed to bottom out the car while creeping over road under repair. Now when I turn, the steering wheel does not return back to center. It is a little harder to turn the wheel and when turning I hear a dragging noise, like its hitting against something. I started looking for replacement electric power steering units but don't even know if that what is wrong. Anyone else experience this? What route did you go fixing this issue? Thank you!
Old Jul 31, 2021 | 01:56 AM
ausLX's Avatar
ausLX
How old are your shocks, and are they OEM. If they bottom out they might need replacing. Anyway, did you get under the car and look at your suspension components to try and see what the issue is. It might be your tie rods if you have alignment and steering issues.
Old Jul 31, 2021 | 06:21 AM
Nospinzone's Avatar
Nospinzone
I agree with ausLx, I think you damaged part of the steering mechanism or suspension. I would have this checked before you do any more driving with the car.
Old Jul 31, 2021 | 08:51 PM
Gennady7's Avatar
Gennady7
Thanks for the reply.
Yes the car is lowered, it just came out of the shop and I still have the oem wheels on (didn't swap out my summer set yet).
When I bottomed out, I hit a manhole cover. I had the mechanic pick up the car, he says its the steering rack but he quickly glanced and I feel like I need a second opinion.
When I turn slightly to the right, the car continues to drive straight. I find myself driving the steering wheel a lot to the right. It does not only feel like an alignment issue, it feels like I lost part of the steering. In addition, the steering wheel does not come back to center after a turn.
I found a replacement electric rack and pinion from a junk yard in LI for 400 with 6 month warranty.
Old Aug 1, 2021 | 12:01 AM
ausLX's Avatar
ausLX
Why didn't you include all that info in your OP. You're here asking for advice but you're not very forthcoming with the details, and the more you leave out the harder it is for anyone to help you. Why don't you get the problem correctly diagnosed before you go buying parts?
Old Aug 1, 2021 | 08:58 AM
Gennady7's Avatar
Gennady7
I posted as soon as it happened. If you have no feedback, skip it. I don't have issues with suspension, I have an issue with steering.
There's no codes, and correctly "diagnosing" requires disassembly.
I am not 100% that it is rack and pinion because it could be damaged tie rods. It also might be in addition to the rack.
ChocosLS430
Oct 12, 2024 04:47 PM
DMike
Jul 29, 2023 01:24 PM
slinky
Apr 17, 2017 02:00 PM
Kennyr44
Mar 15, 2016 01:20 AM
