KYB front shocks too soft
Old Jul 27, 2021 | 07:12 PM
user 710812323's Avatar
user 710812323
Default KYB front shocks too soft
My suspension was checked over recently when I had it in for an alignment. It was found that the front KYB shocks I replaced just over a year and under 15k miles ago allow too much jounce. The rear seems to be working like it's supposed to. No other issues with the suspension were found. I kind of think they might have been soft right from the start. The front has ridden a bit weird since they were installed (no real experience with this car before the KYBs were installed).
Is this normal KYB operation?
Old Jul 28, 2021 | 10:26 AM
JLAWS's Avatar
JLAWS
Are they KYB gas A Just struts or regular KYBs? I had great experience with Gas A Justs. Maybe your springs are worn?
Old Jul 29, 2021 | 06:05 PM
user 710812323
They are the Gas-A-Justs from Rockauto
https://www.rockauto.com/en/moreinfo...&pt=7584&jsn=1
I'm getting about 3 bounces when you bounce and let it go.
Old Jul 30, 2021 | 06:49 AM
JLAWS's Avatar
JLAWS
Both sides bouncing 3 times or just one side!! Something is off. Try going over a speed bump slowly. If it bottoms out and hits the rocker panel then the struts are defective or you might need new springs which is rare. How many miles on your car?
Old Jul 30, 2021 | 03:00 PM
user 710812323
Seems to be a pretty even bounce (both right and left side). I don't know about hitting the bumper stops going over speed-bumps, but it's definitely less controlled than the rear. Multiple bounces and too much up-down action. I have 118k miles.
I'm wondering if there was a mispackaged or bad batch.
Old Jul 30, 2021 | 04:35 PM
scutch's Avatar
scutch
On a similar note, now that I see this post. I just got my 4 Gas A Justs from Rock Auto today, shipped to a friend in the next county because of some new tax rules or something that creates a lot of work for Rock Auto, so they no longer ship to certain counties in Colorado.
Is there a way to check new shocks before you put them in?
Old Jul 31, 2021 | 09:34 AM
user 710812323
No way that I'm aware of. I'll also add that it feels like the front end is more jarring going over sharp bumps than it should be for an LS. It's strange feeling. Floaty but jarring at times. Tire pressures are 32. Rest of the suspension looks good and is aligned.
Old Jul 31, 2021 | 10:22 AM
scutch's Avatar
scutch
This is my first LS460 2007 and I got it with 150k on it, so I have put 20k on it. I am not even sure what to expect when I replace the shocks as far as feel goes. But I'll be happy when the clunk in rear shock goes away. I'll be replacing at least the lower, main control arms on the front end as well. 48640-50131, 48620-50131 A little wobbling in the steering when I brake sent me in to my mechanic to find the lower, main bushing was pretty bad. They tested the front rotors and they were true. At the very least, I'll do a bounce test before the strut replacement so I have something to compare it to.
Old Aug 4, 2021 | 07:06 AM
user 710812323
2 of my socks blew the second day I had my car (dealer reimbursed me for it). I'm curious how a LS should ride. Between the shocks, poor assignment and wheel balance (trusted a local shop with a good reputation and on all accounts stopped using them for failing to do basic work correctly), actual bent wheels (again, shop failed to diagnose when I asked them specifically what could be causing vibrations), and out of round tires I don't think my car has ridden properly since I bought it. I'm still working through getting things fixed.
Old Aug 4, 2021 | 08:07 AM
Anfanger's Avatar
Anfanger
I did too had issues with out of round tires, ruined suspension, and poor alignment. It made the car barely drivable. It took me 9 months to improve the right quality to the level I actually enjoy it.
Old Aug 6, 2021 | 08:32 PM
user 710812323
Sounds really familiar. Gotta say I'm just not enjoying this car yet. I'm trying.
colfax
Jul 4, 2018 06:41 AM
RA21262
GX - 1st Gen (2003-2009)
Dec 7, 2016 12:38 AM
cssnms
20
Sep 17, 2015 06:54 AM
GRAYM
16
Sep 1, 2013 09:43 AM
Giggzz
Jul 31, 2007 04:24 PM
