09 ls460 awd air shock compressor reset?
Old Jun 7, 2021 | 10:51 AM
kb1111's Avatar
kb1111
Default 09 ls460 awd air shock compressor reset?
Hi. I replaced my front driverside air shock and now the suspension is not leveling I beleive because the compressor is not turning on. Is there a way to reset the compressor? Thank you.
Old Jun 7, 2021 | 11:45 AM
Anfanger's Avatar
Anfanger
You probably disturbed the height sensor.In the same time, make sure that you connected the strut wire harness properly.
Old Jun 7, 2021 | 12:29 PM
kb1111's Avatar
kb1111
@Anfanger Thank you for the reply. I have checked the connection of the strut wire harness. Can I reset the height sensor? Would disconnecting the battery help?
Old Jun 8, 2021 | 04:24 AM
Anfanger's Avatar
Anfanger
When, I replaced my struts, I did not need to reset anything. But yes, you can reset all ECUs and sensors by disconnecting the battery for a while.
Did you check the sensor for any damage or misalignment? Check the sensor harness. Compare it to the right side if there is any difference aside from being a different side.
Old Jun 8, 2021 | 04:43 AM
lwphat66's Avatar
lwphat66
Were you able to verify the air compressor is cycling on, or if any of the shocks are raising/lowering? You may want to try turning the Height High switch on and listening at the front passenger side for the compressor. Also wait a few minutes to see if the car raises. If there is no issue with the actuator/connection, it might be necessary to do this a few times and observe the results. Good luck!
Old Jun 8, 2021 | 08:28 AM
kb1111's Avatar
kb1111
@Anfanger. Thank you for the reply. Checked the sensors and connections all look good. When you say disconnect the battery for a while, how long would be good?
Old Jun 8, 2021 | 08:43 AM
kb1111's Avatar
kb1111
@lwphat66 Thank you for the reply. It doesnt sound like the compressor is running. No movement up or down switching height back and forth.
ssgi4in12
RX - 1st Gen (1999-2003)
May 17, 2018 12:58 PM
kevlo911
NELOC
Jun 27, 2016 06:53 AM
rk4g63
May 1, 2013 08:09 AM
LS430Lexus
Dec 5, 2012 11:23 AM
JFNash
Jul 16, 2012 03:12 PM
