460l
Old Dec 17, 2020 | 10:07 PM
macLexy55's Avatar
macLexy55
Default 460l
I just bought a 2008 LS 460L, and I'm also a newbie here 😀 I have had Lexus and Toyota cars previously for the obvious reasons .... reliability, quality, parts etc, and of course all the fun and different gadgets that set Lexus apart from other cars. I have a familiar problem right now of the VSC warning coming on, and staying on. I know that there is ways to turn this off, which I would gladly accept any advice on, but I would like to know if this is all that is required, or should there be any need to repair or replace any parts. Also, the light is not working on one of the pop down mirrors in the back seat area. Was wondering if this is a fuse or bulb issue.
Old Dec 18, 2020 | 08:52 AM
Nospinzone's Avatar
Nospinzone
Congrats on your new car and I wish you good luck with it. And welcome to CL.
As far as your question, this thread may have useful information for you https://www.clublexus.com/forums/ls-...-messages.html
At the top of this forum there is a FAQ sticky, plus you can also search the forum.
Old Dec 18, 2020 | 09:59 AM
macLexy55's Avatar
macLexy55
Thanks for welcoming to CL and for pointing me in the right direction.
Old Dec 18, 2020 | 10:36 AM
DedBirdDog's Avatar
DedBirdDog
Welcome and good luck with your new car. I hope that you don't come to seriously wish you had joined here and researched first prior to buying your car. While you are indeed correct about the reputation that Toyota/Lexus enjoy, the 2007-2010 LS series has some unique and sadly, sometimes VERY costly issues.
Old Dec 26, 2020 | 09:37 PM
macLexy55's Avatar
macLexy55
Thanks dedbirddog, but as I said in my introductory post, I have had many Lexus and Toyota cars in the past, hence the reason I had carried out my research prior to buying the car. However, you are not always going to catch everything every time, the most important thing is that you do spot it as quickly as possible and get it rectified right away. And as you correctly pointed out to all of us, it can be very costly.
Tho, no use buying a car if you can't afford to spend the upkeep on it .... it's a bit like booking an exotic holiday and spending the whole time in your room eating sandwiches. No point on going if you can't afford to enjoy yourself 😎
Old Dec 28, 2020 | 07:06 AM
R Z's Avatar
R Z
Good answer.
Allusuc
Dec 15, 2020 04:02 PM
JohnOlson
Aug 29, 2020 12:11 PM
drrishi
Oct 29, 2015 07:31 AM
nickvillan
Feb 25, 2010 02:50 PM
flyguyskt
Maintenance
Apr 29, 2009 07:32 AM
