Front Turn Signal LED Switchbacks
Old Nov 28, 2020 | 08:26 AM
naterdee's Avatar
naterdee
Default Front Turn Signal LED Switchbacks
Anyone had any luck doing this? Can a particular canbus bulb be used without a flasher module? Appreciate any tips! thanks
Old Nov 29, 2020 | 09:16 AM
naterdee's Avatar
naterdee
I cant believe nobody has done this ever lol. Lil Help guys!
Old Nov 29, 2020 | 09:59 AM
According to this you need an LED flasher and of course the bulbs
https://www.diodedynamics.com/by-veh...s-ls460-317306
Hopefully someone with your car that has installed LEDs will post.
Old Dec 21, 2020 | 07:55 AM
naterdee's Avatar
naterdee
I Bought these Sirius LED Rear Turn Signals in Red to test if the built in Anti Hyper Flash works without using the flash relay module and it does! I chose the red color to match the red led built in tail light of the car. they look great and very bright.
HOWEVER! I just answered my own question. Since 7440 Led Bulbs are *Single Filament* (7443 are Dual Filament and the only way you can get a switch back LED in our size) - While the 7443 will work in in the socket, there aren't 2 sets of contacts to power the *White* portion of the switchback LED, thus it will only function as an Amber turn signal and never *Switch Back* to white after the turn signal is switched off.
see link for Anti Hyper Flash LED Signal Lights (These will not hyper flash 100%):
Amazon Amazon
Grisik
Jul 18, 2021 03:02 PM
4TehNguyen
LFA Model (2012)
Jan 12, 2021 05:12 PM
NikNikNik
Sep 5, 2019 06:49 AM
h2osmokey
RX - 1st Gen (1999-2003)
20
Sep 29, 2007 06:45 PM
