Vibration noise
Old Nov 17, 2020 | 10:10 AM
Jvfls460's Avatar
Jvfls460
10th Gear
Default Vibration noise
So I noticed a noise coming from car at low speeds sounds like when u go over a center line an hit the grooves it only lasts a few seconds an is sparatic hard to duplicate . At first thought it was tires rubbing an the tread making the noise but can’t find rub marks .. the thought compressor making noise or brakes dragging I’m at a loss .. car still has rear airstruts fronts are coil overs can’t get suspension to go up with height high any suggestions
Old Nov 17, 2020 | 06:45 PM
Jvfls460's Avatar
Jvfls460
10th Gear
The noise sounds like I’m goin over rumble strips
Old Nov 17, 2020 | 07:51 PM
ReLexing's Avatar
ReLexing
You may want to start looking at the wheel bearing (hub) post. That is how they sound when they are bad. Sort of like a set of mud tires on pavement.
Old Nov 26, 2020 | 11:39 AM
Jvfls460's Avatar
Jvfls460
10th Gear
Pretty sure I pinpointed it it’s the transmission not down shifting at lower speed pretty much like trying out a stick shift in 4th doin 30 mph
Old Dec 9, 2020 | 10:06 PM
JBrownKC's Avatar
JBrownKC
Just went through this. Rumble strip sounds. Booming like a subwoofer. Lexus said I needed a new transmission and torque converter. Just had the fluid changed at a transmission shop. So far the noise is gone and vibration. Took around 50 miles or so to go away. $200 fix.
Old Dec 9, 2020 | 11:04 PM
Jvfls460's Avatar
Jvfls460
10th Gear
Yes I narrowed it down to transmission staying in higher gear at 30-40 mph pretty much like a stick shift in 4th gear at low speed I did a drain an fill of 3 qts also fixed it so far I’m scheduled to do a drain an fill again at end of month can’t hurt
celsior123
Oct 21, 2014 05:09 PM
pinoiryder
Feb 7, 2011 09:50 AM
RXGS
May 22, 2010 04:18 PM
