What systems control cruise control ?
Old Nov 6, 2020 | 06:55 AM
jdanielca's Avatar
jdanielca
Default What systems control cruise control ?
I just read that the jap sec and euro spec 2097 have all speed and up from 30kph respectively which is quite useful for me but I can’t seem to find a cruise control ecu or find out what parts i need to swap out to gain this feature can’t be that hard
Old Nov 6, 2020 | 07:21 AM
Anfanger's Avatar
Anfanger
Cruise control is most likely controlled by the main ECU as it requires connection and feedback from majority of the systems.
Old Nov 12, 2020 | 12:30 PM
cochiseg's Avatar
cochiseg
I heard it runs with a vacuum system, not sure about the LS
somehow, this vacuum pressure holds a second throttle until the brake is pressed?
Old Nov 12, 2020 | 12:54 PM
Vansibel's Avatar
Vansibel
DSU (Driving Support Unit)
Might not be as easy as a swap without triggering codes though
Old Nov 13, 2020 | 01:44 AM
cryptodonis's Avatar
cryptodonis
Old Nov 13, 2020 | 02:11 PM
piercejr's Avatar
piercejr
Originally Posted by cryptodoni
heh, all that and I don't see any throttle actuator.
Old Dec 20, 2020 | 01:25 PM
BlazeViper's Avatar
BlazeViper
The hybrids looked to always be able to do this as all of them seemed to ship with certain precrash bits like the stereo camera and object recognition ECU. 2013+ all seem to have the stereo camera mounted even without the APCS option which I would assume is what gives them all speed cruise control. As long as you have radar cruise you have the driver assist ECU, I'm wondering if I retrofit the camera, recognition ECU, would I be able to gain all speed cruise somehow. I better start surfing the comma AI wiki and take a CAN training course.
Old Dec 20, 2020 | 09:51 PM
jdanielca's Avatar
jdanielca
to get commas ai to work I think you need APCS. There’s a Thread about it o have not had the chance to see if I have the required wire in the trunk
Old Dec 21, 2020 | 02:02 AM
ALK's Avatar
ALK
I know for a fact that you can add a radar cruise control by just swapping a driver support unit and installing the radar. Regarding the all speed feature that works in together with the stereoscopic camera which uses the object recognition ECU. So you need to already have APCS.
Old Dec 21, 2020 | 06:19 AM
jdanielca's Avatar
jdanielca
Was it you that started the thread about the APCS? I need to have a look at that again. Looks like it might be a worth while mod if possible just because it lets you do so much more.
Pgxxl
NX - 1st Gen (2015-2021)
Nov 1, 2020 12:34 PM
GibbsLexus
Sep 8, 2020 11:22 AM
villamora
Jul 16, 2017 10:28 AM
