How to remove front lower control arms?
Old Oct 30, 2020 | 07:21 AM
Anfanger's Avatar
Anfanger
Question How to remove front lower control arms?
I am going to be replacing all front control arms on my 10 AWD 155k. I have done upper ones already when I replaced bushings and I know how to remove and install it. The lower control arms are more challenging, particularly, rearward ones due to adjusting toes (I believe, it is called that). I got original arms, so it seems, and the adjusting toes are "fused" to the arms. I was wondering if anybody had luck removing it and willing to share some tips.
In between, I am aware that the arms need to be torqued under load.
Old Oct 30, 2020 | 08:50 PM
sha4000's Avatar
sha4000
Can you post a pic of the control arm?
Old Oct 31, 2020 | 02:17 AM
Vansibel's Avatar
Vansibel
I also got stuck at this point when doing mine, managed to remove the main bolt but as you probably saw it slide into the adjusting toes which goes through the bushing. Mine was also seized and there is not much room to use tools to push it out. Shop had to cut it in half and install new ones. They also did the same thing on the lower front ones but after that they realized the cam bolt on those were back order everywhere in North America. So my car will sit at their lot for at least a month or god knows until when as not a soul can tell when this part will be back in stock.
Old Oct 31, 2020 | 06:55 AM
Anfanger's Avatar
Anfanger
I will later, it is 19F outside right now.
Old Oct 31, 2020 | 06:57 AM
Anfanger's Avatar
Anfanger
I ended up cutting one off arms in pieces but ran out of cutting disks. I had only 4.5 inch disk and it is too small. I am going to get 6 inch ones that should allow me cut the arms in fewer steps.
Old Oct 31, 2020 | 07:42 AM
sha4000's Avatar
sha4000
I was asking for a pic of the new arm which I thought you had already. I'm trying to visualize what you are talking about.
On my RWD I have to cut that arm out with a sawzall.
Old Oct 31, 2020 | 08:16 AM
sdls's Avatar
sdls
The job sounds miserable.. when Beck brings the AWD lower control arms back in stock and I do mine, I’ll have to make sure I get new camber bolts. Had to grind off the ones on my 86.5 Supra too many years ago, and it really sucked.
Old Oct 31, 2020 | 03:17 PM
Anfanger's Avatar
Anfanger
I cut off the front left rearward arm but front lower forward control bolt is stuck. I got all spare parts but the bolts. I even found a inner tie rod removal tool at the local AutoZone. I have to call the local Lexus on Monday to order more parts.
I have replaced sway bar bushings which is 1% of what I was going to do.
Old Nov 1, 2020 | 04:43 AM
Vansibel's Avatar
Vansibel
Is the part #48190-50060 what you looking for ? Should be the same as my ls600hl. Please let me know if you find any dealer that have them in stock in the US (i need 2), they are are back order everywhere around there and although I ended up ordering them from japan they might take a months to get there and right now my car is stuck at the shop. Don't mind paying twice to get them sooner.
Old Nov 1, 2020 | 11:13 AM
Anfanger's Avatar
Anfanger
I am going call my local Lexus tomorrow. As far as I am aware, Lexus dealers share parts. If you couldn't get at your local dealer, most likely, my local dealer will not have either. On other side, I got all my parts from Emirates.
Old Nov 1, 2020 | 11:14 AM
Anfanger's Avatar
Anfanger
5x 6-inch cut-off metal disks later, I got all front control arms removed. I can see why Lexus charges so much for this job.
Old Nov 1, 2020 | 03:43 PM
Vansibel's Avatar
Vansibel
I live in Canada I'm not sure US and Canada dealers share parts
Old Nov 1, 2020 | 03:48 PM
Anfanger's Avatar
Anfanger
I will update my post when I get more information from the dealer. I am a little nervous about availability of the parts.
Old Nov 1, 2020 | 05:39 PM
sdls's Avatar
sdls
why does every single repair on this stupid car have to be an adventure?
Old Nov 1, 2020 | 07:20 PM
Anfanger's Avatar
Anfanger
I was wondering about that as well! My wife is not happy about this car. Owning only Toyotas before we never had such problems, until now.
I replaced both belt pulleys today, both had rattling bearings.
