Wouldn't using an XP virtual machine work just fine? Finding an old 32 bit laptop and then getting XP on it seems quite the hassle and expensive. I have a cable coming Sunday and will be able to test the VM out then but I'm pretty positive that should work.
It would but the problem is usually the host OS. It is still needs passthrough an OBD adapter and that is where you get a ton of problems.
I was using XP in a virtual machine on my 17 inch MacBook pro for years until I bought an older much smaller think pad just for techstream.
Is tech stream free? I lost my key for my 06 Lexus I want to reprogram used key into my car anyone know it’s possible? Thanks
Technically, it is not free. The software referred above is to Techstream version with expiration date bypass, it effectively makes it free but not legally.
You can't program a used key from another vehicle unless it has been virginized, you need a legit techstream program and cable to do that or you could get it done by some locksmiths or the dealer.
Reviving this old thread. I recently downloaded Techstream onto an old laptop because i needed one dedicated to my shop for tuning my LS460. Problem is, its asking for a dealer name, dealer phone, dealer code, and state region...any ideas where I can get this information?
