Vsc VGRS reset ?
Old Sep 13, 2020 | 07:32 PM
Jvfls460's Avatar
Jvfls460
10th Gear
Default Vsc VGRS reset ?
Vsc VGRS lights are both on just bought car replaced both front struts car acts wierd changing lanes kind of bummed might be Ton of issues other lexs use the obd2 jumper method to reset .. no codes in scanner any help ? Was salvaged from wreck in front an passenger side could it be a sensor they didn’t fix ?
Old Sep 14, 2020 | 08:51 PM
sdls's Avatar
sdls
Sounds like you should check out the height sensors that connect to the lower control arms, if one of them doesn’t signal properly it could result in the symptoms you describe
mandyfig
Jun 20, 2022 04:29 PM
Cashed2JZ
Aug 26, 2019 04:21 PM
shmuliebz
Nov 8, 2017 06:15 PM
ZeekGS300
Jul 28, 2010 09:35 AM
audphile1
Apr 9, 2009 09:10 PM
