Idle mode
Old Sep 10, 2020 | 07:32 AM
Santa01's Avatar
Santa01
Default Idle mode
Howdy folks, Santa here, I have been perusing this forum for a while and WOW there is some good info here. I am new to the LEXUS family and have really enjoyed my car. She is a 2008 LS460 with 175,000 miles. I have replaced the upper and lower control arms. That was a punch in the gut! Still I got a very good deal on the initial purchase. I had her serviced by Lexus of Chattanooga, it was the 175,000 mile maybe the 150,000 mile service. Quite extensive service, they also ordered new interior parts for me. Nice, can't wait for them to come in. I am now experiencing another gremlin, Twice she has gone into IDLE mode. Engine lights come on, VSC code, traction control, the works. She also goes to a slightly higher idle and stays there. I can disconnect the battery for a few seconds and everything resets. I have checked the battery, twice and also replaced my gas cap. The shop says no codes because I disconnected the battery so they can't read anything. O'Riellys, ran a code before I disconnected the battery and said Throttle position sensor. The mechanic told me the dealer says I have to replace the entire throttle body as the sensors are not replaceable! Has anyone run into this situation? Thanks guys, Y'all have a GREAT DAY.
Old Sep 10, 2020 | 07:42 AM
sdls's Avatar
sdls
It does look like your mechanic is correct unfortunately. The throttle body has a motor controlling the intake butterfly valve as the car is a drive-by-wire setup.
Old Sep 10, 2020 | 07:46 AM
Santa01's Avatar
Santa01
Thanks for the quick and informative reply. The shop says about 1,200.00, sound about right to you? Any info as to this problem will be very much appreciated. Thanks
Old Sep 10, 2020 | 08:02 AM
Anfanger's Avatar
Anfanger
Get an used one in a good condition from Ebay. It will cost you ~$200. Make sure to get it from a seller with a good reputation.
Old Sep 10, 2020 | 08:14 AM
sdls's Avatar
sdls
There would be a lot of profit involved at that price point. Actual labor time would be quite brief on this repair.
I’m not sure if there is a procedure involved to mate a new throttle body to the cars control system. As stated below (above?), a used unit from a salvage yard would save a lot of money.
Old Sep 10, 2020 | 08:22 AM
Santa01's Avatar
Santa01
That is a good idea, thanks. would I need to have it hooked up to calibrate? Meaning will it work if I just shade tree replace it?
Old Sep 10, 2020 | 09:38 AM
Santa01's Avatar
Santa01
Have you replaced one and if so any suggestions? Thanks
Old Sep 10, 2020 | 11:17 AM
jdanielca's Avatar
jdanielca
check how much the part is at www.lexuspartsnow.com but the labour objectively speaking even for a total idiot is 1hr max I have remove the throttle body before
Old Sep 10, 2020 | 12:59 PM
Santa01's Avatar
Santa01
Thanks, I'm still checking to see if it is a plug n play!
Old Sep 11, 2020 | 06:49 PM
miket000's Avatar
miket000
You can buy techstream software on ebay for $40 to program a different throttle body to your LS. The software can be tricky to install if you are not computer savvy.
As an alternative, if your shade tree mechanic isn't good at installing software I have a laptop with techstream pre installed for sale. I have used it on my 2007 ls460. It comes with the mini vci cable to connect to lexus or toyota vehicles. The laptop charger is also included.
Old Sep 13, 2020 | 12:58 PM
Caflashbob's Avatar
Caflashbob
sent pm about the computer
JH48
Jul 15, 2019 06:48 AM
sp9094
RX - 3rd Gen (2010-2015)
Apr 14, 2019 10:54 AM
LsG86
16
Mar 24, 2015 01:14 PM
rorygs300
Dec 2, 2014 12:59 PM
irishcharm
Feb 26, 2012 06:24 AM
