LS460 Ballast Replacement?
Has anyone replaced their headlight ballast? My left headlight is not working even after replacing the bulb and I am guessing this is the problem. Can someone provide instructions or tell me how much it was to get it replaced.
I've done it on a 2007 ES 350. I don't know whether a similar process would be appropriate for an LS 460. It was laborious, and I can understand why a dealer or mechanic could charge a fair bit to do it (at least for a 2007 ES 350 -- I think I was quoted about $1k total a few years ago when I had the issue), even though the price of the ballast could be pretty low.
Here is a link that details the process with images, and my post within that thread which details my steps (post #23). Also, you will see that the op used a process that involved soldering. However, someone found a way to do it without soldering (posts #7 and #11), and I was able to complete the process without any soldering):
https://www.clublexus.com/forums/gs-...headlight.html
In addition, I believe that I purchased the OEM ballast on Amazon.
Good luck!!
Good luck!!
waltermf
Aug 2, 2018 08:01 PM
IStoSC
Jul 9, 2014 06:17 AM
jtork2
IS - 1st Gen (2001-2005)
Jul 13, 2013 09:24 PM
lexusis305
Dec 27, 2011 04:57 PM
