NHV - sometimes
I'm trying to chase down some noises and vibrations toward the rear of my car that aren't always the same or consistant. I've done my best remember all the scenarios in which the different feel/sound has happened. So, here goes...
Has anyone had and fixed similar issues?
- When I first get on the freeway my car vibrates at what feels like a wheel rotation frequency. It pretty much goes away within a mile. I assume it's related to tire flat spotting since the vibration feels busier than tires that are out of balance.
- When I am on the freeway (especially after I just get on the freeway) I also typically get a higher frequency vibration which can be heard (like a subwoofer rumble) and felt. It's typically only above 60mph. This one sometimes goes away just as quick as the first bullet point. Other times it seems to continue on for longer. I believe that it greatly reduces or goes away if I let off the gas. When it's happening the amplitude typically comes and goes every 2 to 4 seconds.
- When driving above 65mph I also get a vibration that feels like about the frequency of tire vibration. I want to believe that I can rule the tires out after have the tire balanced>noted bent wheel fixed (to "better-than-new") and re-balanced>all 4 tires re-balanced with road-force balance. This one also seems like it reduces or goes away if I let off the gas.
It's a two piece drive shaft, the vibrations will occur at every order of harmonics on both halves.
I would check it since anytime you left off and vibration reduces/changes it means something in the drivetrain that alters it state from load/absence of load is the generator of the noise. Also check the input bearing of the rear diff and rear trans bearing endplays.
This is assuming you are certain it's not the wheel/tire packs, did you already swap rear to front and see if it followed? It's usually in the tires as stated above
Move the tears to the front yourself or mark them with a paint pen to ensure they move them and see if the steering has vibration and if the noise in the back stopped. If the issue moves around with the tires/wheels the issue is there no matter what the shop might say.
Vibration is still happening at the rear. I did seem to reduce it some by cleaning up the mating surfaces of the hubs, rotors and wheels.
Continuing to investigate...
hmkim
May 25, 2010 12:50 PM
Rexus300
Wheels, Tires & Brakes Forum
Dec 28, 2008 05:57 PM
