TECHSTREAM and BRAKE FLUSH?
Old Mar 6, 2020 | 08:27 AM
colfax's Avatar
colfax
Default TECHSTREAM and BRAKE FLUSH?
after the previous owner had the dealer do a brake flush some 60,000 miles ago it is due for another one
and I have a very good trusted local mechanic who is certainly capable of doing it
but what is this requirement that TechStream is necessary or has to be involved, why?
Old Mar 6, 2020 | 10:06 AM
No, you likely won't need it if you don't let the reservoir run dry and allow air into the ABS block and if you have a high level scan tool you can set the block for bleed mode or even better if the tool can do it have it run the automated bleed. It's rare I ever need to actually use a scan tool on an abs car as long as I do not let it go dry.
Old Mar 6, 2020 | 01:46 PM
BMW7_LS430's Avatar
BMW7_LS430
This is one service worth going dealer to. Few people reported dealer cost $110. Do DIY only if you feel very confident and know what you are doing. There are threads on how people did it. Any screw-up can potentially cost you $3K.
Old Mar 6, 2020 | 02:23 PM
Kuhan's Avatar
Kuhan
It’s a two man job with Techstream. It’s a bit complicated. It’s something I’m worried to do it by myself too even I’m a diy’er. The price to do proper brake flush is around $350-400 at the Lexus dealers and at the Toyota dealerships. It’s not $110. Last time I paid Lexus to do a ‘brake flush’ was $95. All they did was sucking old fluid out of the reservoir and filled with new fluid.
If you are brave enough to do it yourself, please do a tutorial on the steps. Thanks.
Old Mar 6, 2020 | 03:08 PM
BMW7_LS430's Avatar
BMW7_LS430
Here is the process. https://www.clublexus.com/forums/ls-...ml#post8637802
kukudm
NX - 1st Gen (2015-2021)
14
May 22, 2019 06:32 PM
Wallander
RX - 3rd Gen (2010-2015)
Jan 20, 2017 10:11 AM
jimbosr1
May 19, 2014 11:01 PM
GS714
Lexus Vehicles Classifieds
Apr 7, 2012 02:08 PM
HimSelf
Dec 7, 2010 01:25 PM
